Cannot ping from one network to another when using two switches
undercloud
I am trying to ping from network 192.168.0.0 to network 172.162.0.0 with no success. It relates to an exercise, for a back-up network connection. does anyone have any idea why I can't ping from one network to another? Thank you
PC1: Network 192.168.0.0 vlan 10
interface FastEthernet0/1
switch port access vlan 10
interface Gigabit Ethernet0/1
switch port trunk allowed vlan 10
switch port mode trunk
interface Gigabit Ethernet0/2
interface Vlan1
no ip address
shutdown
interface Vlan10
ip address 192.168.0.1 255.255.255.0
PC2: Network 172.162.0.0 vlan 20
switchport access vlan 20
interface GigabitEthernet0/1
switchport trunk allowed vlan 20
switchport mode trunk
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
interface Vlan20
ip address 172.162.0.1 255.255.0.0
17 Replies 17
thanks, i did as you said and it works with just the same vlan on the 2960 switch to ping
I run lab using the SW model you mention and as @Martin L  suggest before you need to change the SW this SW not support L3 (can not config ip routing on it) and this cut the inter-vlan.
so lab can not done as you like with this SW.
thanks for your help both, it worked now
