Cannot ping two host using SVIs?
petey1984
Frequent Visitor
Frequent Visitor
Hello I have setup two ports with two host conencted to them one with address 10.1.70.2/24 and the other is 10.1.80.2/24. I created two SVIs(VLAN70 = 10.1.70.1/24 and VLAN80 = 10.1.80.1/24).
However I am unable to ping the two hosts. Each host can ping each of the SVIs but cannot ping each other.
Please help, the following are my configs:
Current configuration : 1637 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname SW1
no aaa new-model
no ip subnet-zero
ip routing
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0/1
shutdown
interface FastEthernet0/2
shutdown
interface FastEthernet0/3
switchport access vlan 70
switchport mode access
interface FastEthernet0/4
switchport access vlan 80
interface FastEthernet0/5
interface Vlan70
ip address 10.1.70.1 255.255.255.0
interface Vlan80
ip address 10.1.80.1 255.255.255.0
ip classless
ip http server
ip http secure-server
control-plane
line con 0
line vty 0 4
privilege level 15
password password
no login
line vty 5 15
privilege level 15
password password
no login
end
Have I configured it correctly? Ip routing is enable but am still unable to get the hosts to ping each other.
All host are configured correctly with their ip add and default gateway.
Please help??
8 Replies 8
Reza Sharifi
Did you also create the layer-2 vlan for each one
config t
vlan 70
name test vlan
vlan 80
name test1 vlan
one more thing
do the hosts have firewall software on them that could be blocking ping?
I wonder why the original poster has this in the config
no ip subnet-zero
I believe that modern Best Practice is to enable subnet zero.
But I do not believe that this has anything to do with the problem that is asked about in this thread.
I believe that Reza makes a good point in asking about whether the layer 2 vlan was actually created.
It the original poster confirms that the vlans are correctly created, then I would suggest that a very common source of this kind of problem is that the PCs may have a firewall enabled that does not permit ping to the PC. So I would suggest a test in which the original poster goes into both PCs and disables any firewall that may be running.
Rick
Rick
Hi Reza,
Yes I have configured the layer 2 vlans, as you can see:
SW1#show vlan
VLAN Name                             Status    Ports
1    default                          active    Fa0/1, Fa0/2, Fa0/5, Fa0/6
                                                Fa0/7, Fa0/8, Fa0/9, Fa0/10
                                                Fa0/11, Fa0/12, Fa0/13, Fa0/14
                                                Fa0/15, Fa0/16, Fa0/17, Fa0/18
                                                Fa0/19, Fa0/20, Fa0/21, Fa0/22
                                                Fa0/23, Fa0/24, Gi0/1, Gi0/2
2    VLAN0002                         active
3    VLAN0003                         active
10   management                       active
70   testsvi70                        active    Fa0/3
80   testsvi80                        active    Fa0/4
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
Hey Richard I will check the hosts and try disabling the firewall to see if that resolves the issue....
Hi Peter,
Window 7 has firewall enabled by default.  You would need to go and disable the services for it.
see below link:
http://windows.microsoft.com/is-IS/windows7/Turn-Windows-Firewall-on-or-off
Jeff Van Houten
Level 11
Level 11
What model switch is it?
Sebastian Hughes
If you debug ICMP are the pings leaving the switch? Also have you tried to Wireshark the PCs to see if they are recovering the ping?
  I agree with Reza , if you ping the default gateways from the clients but just not to the client , this is most likely a windows firewall or any other type of software FW that it needs to be turned off.
Hi Peter,
I suggest for troubleshooting this you need another L2 Switch. Then make a Trunk connection from your L2 Switch to your L3 Switch. Then try to ping the hosts. You should have the VLANs also on the L2 Switch.
Make sure to disable firewall on the hosts
Eli
