Bookmark
Subscribe
2985
Cannot reach gateway through routing switch (3750)
kerry-davis
Hi, all.
I'm running into what seems a basic ip routing config problem with a Catalyst 3750 (IP Base) switch.  Hoping someone can point out the error of my ways.
I have several VLANS configured on the switch with IP routing enabled, and the switch is connected to the inside interace of a new ASA 5520 as follows:
  • ASA5520 IP (Default gateway): 192.168.1.1
  • Switchport Gi1/0/1 is configured as a routed port, IP address 192.168.1.3 255.255.255.0
  • Example VLAN is VLAN 100, IP address 192.168.100.1 255.255.252.0
From the switch CLI, I can ping all VLAN addresses, as well as the ASA5520, and the client laptop I'm testing with from VLAN 100.
From the client laptop on VLAN 100, I can ping all switch interface and VLAN addresses (inter-VLAN routing is working), including 192.168.1.3, but I CANNOT ping the default gateway at 192.168.1.1.
Here is the relevant configuration information on the 3750:
no aaa new-model
switch 1 provision ws-c3750x-24
system mtu routing 1500
ip routing
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0
no ip address
no ip route-cache cef
no ip route-cache
interface GigabitEthernet1/0/1 ***routing port connected to inside interface of ASA
no switchport
ip address 192.168.1.3 255.255.255.0
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5  ***Client testing laptop connected here on VLAN 100
switchport access vlan 100
switchport mode access
spanning-tree portfast
**SNIP**
interface GigabitEthernet1/0/23
switchport trunk encapsulation isl
switchport trunk allowed vlan 1,2,4
switchport mode trunk
interface GigabitEthernet1/0/24
switchport trunk allowed vlan 20,100,200
**SNIP**
interface Vlan1
no ip address
shutdown
interface Vlan2
ip address 192.168.2.4 255.255.255.0
interface Vlan4
ip address 192.168.4.2 255.255.255.0
interface Vlan20
ip address 192.168.20.1 255.255.252.0
interface Vlan100
ip address 192.168.100.1 255.255.252.0 ***Client from this VLAN cannot ping ASA, can ping sw routing port
interface Vlan200
ip address 192.168.200.2 255.255.252.0
router rip
network 192.168.1.0
network 192.168.2.0
network 192.168.4.0
network 192.168.20.0
network 192.168.100.0
network 192.168.200.0
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ip http server
ip http secure-server
ip sla enable reaction-alerts
**SNIP**
SWOKCCS01#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 192.168.1.1 to network 0.0.0.0
C    192.168.4.0/24 is directly connected, Vlan4
C    192.168.1.0/24 is directly connected, GigabitEthernet1/0/1
C    192.168.2.0/24 is directly connected, Vlan2
S*   0.0.0.0/0 [1/0] via 192.168.1.1
C    192.168.200.0/22 is directly connected, Vlan200
C    192.168.20.0/22 is directly connected, Vlan20
C    192.168.100.0/22 is directly connected, Vlan100
2 Accepted Solutions
amigomnemonik
Looks like you need to create static routes on ASA back to your subnets and on the switch default static route with next hop of internal ASA interface.
Sent from my iPhone
Richard Burts
Kerry
You have given us good information about the switch and not anything about the ASA. Based on what you have given us so far I would guess that the problem is that the ASA does not have any route to network 192.168.100.0 (and probably not the other networks that are defined on the switch). Can you check the ASA and tell us what is in its route table?
Rick
Rick
amigomnemonik
Sent from my iPhone
Richard Burts
Kerry
Rick
Rick
Rick and Kamil -
You're both right about this one. I was so focused on the switch config and the fact it could ping the firewall, I neglected to realize firewall doesn't actually know about the .100 subnet
I added a network object and the proper route in the ASA and now traffic is flowing.
Thanks for the super-fast replies!
Kerry
Kerry
I am glad that you solved the problem and that our suggestions pointed the way. Thank you for posting back to the forum indicating that the problem was solved and marking the question as resolved. It makes the forum more useful when people can read about a problem and can know that a solution was found. Your marking has contributed to this process. I encourage you to continue your participation in the forum.
Rick
Rick
