Cannot Reach Switch that is Directly Connected
Matthew Martin
Level 5
Level 5
Hello All,
We've recently moved to a 3rd Party (*non-AnyConnect) Always-On VPN Cloud service. Issue only occurs while I have the VPN service enabled on my PC (*IT Dept can temporarily disable connection).
In the location in question, we have a Cisco 9500 stack that is our "Core switch", and then a stack of 3 x Cisco 9200s. The VPN provider's on-site box connects directly to the 9200s. But, the LAN addresses they are using to route internally have their Gateway configured on the 9500 core (*Int Vlan100).
Now, if I'm connected to the VPN service and I attempt to SSH or even Ping the 9200, I cannot. A traceroute from my PC to that 9200's address just dies at the Vlan Gateway address on the Core that's used for the LAN addresses of the VPN boxes. Hopefully that made sense...
From the 9500 CLI, if I attempt to ping the 9200 and source that Vlan address, the pings failed. So I added a route on the 9200 pointing back to the 9500 address.After that, the ping started working from the 9500 to the 9200. But, I still cannot SSH or ping the 9200 from my PC. I then added a new Vlan on the 9200 on the same subnet as that Vlan gateway on the 9500, and removed that static route and the pings between the switches still work. But still no SSH or ping from my PC.
A lot of hands have been in the configs since our main networking guy left the company so some of the routes configured are a bit confusing... So I'm going to try and only include the relevant configuration parts.
One odd note is that there's a 3rd 9200 switch, called "9200-TOR" in the config below that I have no problem pinging and SSH to. So I'm including some of those bits as well...
9500 Relevant Config:
9500-CORE#show run
Building configuration...
version 17.3
!...........cut...........
ip dhcp pool VPNDHCP
 network 10.40.100.0 255.255.255.0
 default-router 10.40.100.1
 dns-server 8.8.8.8 8.8.4.4
interface Port-channel1
 description 9200-Access
 switchport mode trunk
interface Port-channel2
 description 9200-TOR
interface GigabitEthernet0/0
 vrf forwarding Mgmt-vrf
 no ip address
 negotiation auto
interface TwentyFiveGigE1/0/10
 channel-group 2 mode active
interface TwentyFiveGigE1/0/23
 channel-group 1 mode active
interface TwentyFiveGigE2/0/4
 description To 9200-Access
 switchport access vlan 208
 switchport mode access
 no keepalive
interface TwentyFiveGigE2/0/10
 no keepalive
interface TwentyFiveGigE2/0/23
 no keepalive
interface Vlan100
 description On-site VPN Device LAN Gateway
 ip address 10.40.100.1 255.255.255.0
interface Vlan123
 ip address 10.40.123.1 255.255.255.0
interface Vlan254
 ip address 10.255.254.2 255.255.255.0
ip route 0.0.0.0 0.0.0.0 10.255.254.1		   !--> SD-WAN
ip route 172.21.0.0 255.255.255.0 10.40.100.251    !--> 172.21 are the client addresses while connected to VPN
end
9200 Relevant Config:
9200-Access#show run
version 16.11
switch 1 provision c9200-48p
switch 2 provision c9200-48p
switch 3 provision c9200-24t
 description Core Uplink
 no ip address
 shutdown
 speed 1000
 negotiation auto
interface TenGigabitEthernet1/1/1
interface GigabitEthernet2/0/29
 description VPN - LAN
 switchport access vlan 100
interface GigabitEthernet2/0/39
 description VPN - WAN
interface TenGigabitEthernet2/1/1
interface GigabitEthernet3/0/1
 description VPN 2 - LAN
interface GigabitEthernet3/0/2
 description VPN 2 - WAN
interface Vlan100
 description ***THIS IS NEW AS OF TODAY***
 ip address 10.40.100.10 255.255.255.0
interface Vlan123
 ip address 10.40.123.2 255.255.255.0
ip route 0.0.0.0 0.0.0.0 10.60.110.2               !-> Our EPL link subnet. Honestly don't know why this default route...
ip route 10.40.100.0 255.255.255.0 10.40.123.1  !-> I've since removed this bc Vlan100 above was added... But having this without Vlan100 above allowed pings to work between switches.
end
Here's some output from my PC:
C:\Windows\System32>
C:\Windows\System32>ping 10.40.123.1
Pinging 10.40.123.1 with 32 bytes of data:
Reply from 10.40.123.1: bytes=32 time=54ms TTL=254
Reply from 10.40.123.1: bytes=32 time=55ms TTL=254
Reply from 10.40.123.1: bytes=32 time=56ms TTL=254
Ping statistics for 10.40.123.1:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 54ms, Maximum = 56ms, Average = 54ms
C:\Windows\System32>ping 10.40.123.2
Pinging 10.40.123.2 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 10.40.123.2:
    Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
C:\Windows\System32>tracert 10.40.123.1
Tracing route to 10.40.123.1 over a maximum of 30 hops
  1    53 ms    56 ms    54 ms  10.40.123.1
Trace complete.
C:\Windows\System32>tracert 10.40.123.2
Tracing route to 10.40.123.2 over a maximum of 30 hops
  1    56 ms    55 ms    55 ms  10.40.100.1
  2     *        *        *     Request timed out.
  3     *        *        *     Request timed out.
  4     *        *        *     Request timed out.
  5     *        *        *     Request timed out.
  ............cut...........
 27     *        *        *     Request timed out.
 28     *        *        *     Request timed out.
 29     *        *        *     Request timed out.
 30     *        *        *     Request timed out.
Trace complete.
Let me know if there's anymore info needed.
Wondering if having the VPN provider change their Gateway to 10.40.100.10 so the GW is on the same device where the VPN boxes terminate... But, don't want to break something else by doing this.
Thanks in Advance,
Matt
@Matthew Martin
 If when you connect to the VPN you receive the IP address on the network 172.21.0.0,  you need to have on the 9200 a return route for this traffic.
If I understood your scenario/problem properly, the 9200 will send the traffic coming from client VPN to 10.60.110.2.
Either you change your default route on 9200 pointing to 9500 or you can add a specific route on 9200
ip route 172.21.0.0 255.255.255.0  10.40.100.1
@Matthew Martin
Hey Flavio, thanks for the reply, much appreciated. About to walk out the door of the office, so I'll give this a shot first thing in the AM.
That makes a lot of sense. I'll comment back after I've given this a try.
Thanks Again,
Matt
Thanks Flavio!
That did it. Very much appreciated!
-Matt
