cant get mmi to work
adamtroxel
My new router (identical to an older one) does not allow me to configure mmi. Keeps returning the "invalid input" for mmi
Here is my sh ver
IVR-2801B#sh ver
Cisco IOS Software, 2801 Software (C2801-SPSERVICESK9-M), Version 12.4(15)T5, RELEASE SOFTWARE (fc4
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Wed 30-Apr-08 15:20 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
IVR-2801B uptime is 35 minutes
System image file is "flash:c2801-spservicesk9-mz.124-15.T5.bin"
Cisco 2801 (revision 7.0) with 118784K/12288K bytes of memory.
Processor board ID FTX1203Z041
2 FastEthernet interfaces
24 Serial interfaces
1 Channelized T1/PRI port
2 DSPs, 24 Voice resources
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
125440K bytes of ATA CompactFlash (Read/Write)
irisrios
Level 6
Level 6
To set the configuration approach for MMI, enter one of the following commands:
mmi auto-configure
no mmi auto-configure
If the auto-configure parameter is enabled, the router is provisioned by the PE. By default, this parameter is enabled.
If the auto-configure parameter is disabled, the router is configured by the startup configuration file.
http://www.cisco.com/en/US/docs/routers/access/soho/software/notes/sciront.html
