Capturing data between two hosts with Wireshark
gscalia01
HI,
I need to capture the traffic on several (specific) IP addresses using my laptop as the distanition using WireShark. I have my span ports all setup on the switch side I just need some help on setting up the filter with Wireshark where all I want to capture is the communication traffic between the two hosts.
Please help.
acampbell
build a capture filter and use the following syntax:-
host a.a.a.a && host b.b.b.b
Alex
Regards, Alex. Please rate useful posts.
