cards
rahman001
Level 5
Level 5
Dear Sir/Ma,
Please kindly help me identify the cards from the attached file.
I want to know the ones that are card.
br
samson
Karthick Murugan
Any part with PFC/MSFC are Supervisor modules.
Any part with ES are Card(Wan card)
Hope it helps
Thanks & Regards,
Karthick Murugan
CCIE#39285
Thanks & Regards, Karthick Murugan CCIE#39285
Hi Karthick,
thanks for your quick response.
please i want to know the smartnets for all these card/supervisor modules.
please identify which ones will have smartnets and the one that will not have smartnets.
please identify which ones will have there smartnets covered by the chassis.
br
samson
You need to work with your vendor to validate this sort of information.
Generally speaking the 7600 ES WAN cards DO require a  Smartnet support separate from the parent chassis. The supervisor, any daughter cards (MSFC, PFC) and clock modules (VTT) generally DO NOT require separate Smartnet.
