09-27-2007 12:59 AM - edited 03-05-2019 06:43 PM
what is the diffrence between cascading of switchs and the uplinks
JD
09-27-2007 03:34 AM
The interconnecting link between both switches which are casecaded is called uplink.
Shaheen
09-27-2007 04:04 AM
Say you had to interconnect 5 switches.
If switch A connects to switch B which connects to switch C which connects to switch D which connects to switch E, this is a cascade.
If switches B through E each connect only to switch A, you would refer to the connections on switches B through E as uplinks and conversely the same connections on switch A to all the other switches as downlinks.
