Cat 3560X Control Plane Policing?
K-Grev
I've gone through the steps on a 3560 to make a control plane policy. ACLS, Class maps, and policy maps. I would like to apply it to the control plane input but it doesnt seem like the commands are there?
Does anyone know the proper way to apply this?
9 Replies 9
Thanks for your reply. It has an ipservices license active.
Can you post show version
follow as suggested guide and let us know what you not able to configure or challenge you have
BB
 I see, I was doing it more in this way.
https://vaulted.io/library/disa-stigs-srgs/cisco_ios_switch_ndm_security_technical_implementation_guide/V-220609
i can do everything but apply it to the control plane.
sho ver: flash:3560e-universal-mz.152-4.E7
can you post the config and give us example what error you getting when you apply ?
BB
I don't necessarily get an error, the command just isn't there for me.
#conf t
#c?
call-home   captive-portal-bypass   cdp   cef
cisp   class-map   cins clock
cluster   cns   coap   configuration
crypto   cts
These are my options.
Normally i believe you would apply it like this: control-plane> service-policy input "POLICY-NAME"
Config attached.
Thanks for your help.
3560 has limited features as per I know, please refer to the guide that is the command syntax available.
BB
So, if adding the policy maps to the control plane isnt an option, i could just add them to some specific interfaces instead to get a similar effect?
When I try this way on a 3560 i can type mls qos but cannot follow that with copp.
