Cat 3650 Flexible Netflow
janvandek
What does Activate Netflow in Access (code FNF-LC) do?
I would like to have Netflow on the Cat3650. Therefore I foresee IP BASE (as needed to support Flexible Netflow).
But now, I'm a bit confused because there exist also a SKU  (90Day trail) to activate Netflow in Access (some product from Lancope Stealthwatch).
What does it, and do I need this ? Can I use Netflow whithout this 90D trail?
Thanks for any comment related to this.
Jan
Don Jacob
As far as I know Cisco Catalyst 3650 supports Flexible NetFlow with atleast an IP Base - no additional requirements. Simply enable NetFlow on your device, use a flow analyzer (SolarWinds NetFlow Traffic Analyzer, ManageEngine, Plixer Scrutinizer, etc.) and you are ready for NetFlow analysis. Hopefully this should help with your Flexible NetFlow configuration:
And this is a sample for Flexible NetFlow config:
http://thwack.solarwinds.com/community/solarwinds-community/geek-speak_tht/blog/2014/01/22/netflow-and-catalyst-switch-netflow-v9-configuration-for-cisco-catalyst-3850-switch
Don Thomas Jacob
http://www.solarwinds.com/netflow-traffic-analyzer.aspx
NOTE: Please rate and close questions if you found any of the answers helpful.
Regards, Don Thomas Jacob http://www.solarwinds.com/netflow-traffic-analyzer.aspx Head Geek @ SolarWinds NOTE: Please rate and close questions if you found any of the answers helpful.
