Flexible Netflow Issue
Rawa Salah
Level 3
Level 3
    HI ALL
Dears
please i can't run the configuration of Flexible Netflow on my switch , the comands are not availabe !!!
please help
Notice / find the following table my switch model and software
Switch Ports Model              SW Version            SW Image
*    1 30    WS-C3750X-24       12.2(55)SE5          C3750E-UNIVERSALK9-M
Model number                    : WS-C3750X-24T-E
PLEASE I NEED NETFLOW HELP ME TO RUN ON MY SWITCH
17 Replies 17
cadet alain
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/software/release/15-0_1_se/configuration/guide/3750xcg/swmnetflow.html
"Flexible  NetFlow is supported only on the Catalyst 3750-X and 3560-X switch  running the IP base or IP services feature set and equipped with the  network services module. It is not supported on switches running the NPE  or the LAN base image. "
Alain
HI Cadet
Dear my Switch model is 3750x , and running this image software "License Level: ipservices".... thats why ask this question ! because my switch has the capablity of running the Netflow but the commands are not available !
..and equipped with the network services module
Dear Jay
please what do u mean ? i dont understand !
Alain
See Cadet's post above..
Dear Jay
My switch is running IP services feature.
Ok... AND it needs to be equipped with the network services module
HI Jay
please i dont understand  need to equipped what ? who can equipped it ?
please Clarify it to me , to get full Rate
Alain
You need 2 things to get Netflow to work on a 3750 -
1- IP Base or IP Services
2- Network Services Module - for example: C3KX-SM-10G Service Module..  Please research for the specific C3KX module for your particular switch
HI Jay
Dear Both of them are obtainable in my switch ( that is why i am asking for )
my switch license level is IP Services , and C3KX-SM-10G module  is exist in my switch ! .
but when i want to run the commands (flow record) , those commands are not available !
Can you run SH VER and post that for us?
Dear Jay
please find the below sh ver output:
sh ver
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 12.2(55)SE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Thu 09-Feb-12 18:14 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x02800000
ROM: Bootstrap program is C3750E boot loader
BOOTLDR:
It uptime is 10 weeks, 4 days, 15 hours, 4 minutes
System restarted at 14:51:37 UTC Sun Dec 8 2013
System image file is "flash:c3750e-universalk9-mz.122-55.SE5.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
License Type: Permanent
Next reload license Level: ipservices
cisco WS-C3750X-24 (PowerPC405) processor (revision A0) with 262144K bytes of memory.
Processor board ID FDO1701W1GR
Last reset from power-on
1 Virtual Ethernet interface
1 FastEthernet interface
28 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Model revision number           : A0
Motherboard revision number     : A0
Daughterboard assembly number   : 800-32727-03
Top Assembly Part Number        : 800-31327-07
Top Assembly Revision Number    : B0
Version ID                      : V04
CLEI Code Number                : COMJV00ARD
Hardware Board Revision Number  : 0x04
So my IOS version is not support Flexible Netflow ?
i should upgrade to ver 15 ?
