Bookmark
Subscribe
1730
Cat:4510R slave-supervisor in unknown
I have replaced two new supervisors in Cat:4510R layer 3 switch. The problem is that, after few times, the slave supervisor is unknown showing in
sh module command. Only one active supervisor is in working. After restarting or re-inserting the slave module, sometime it start working but after few time it is unknown. I have also upgraded the IOS.
Any suggestions/
Aman
Somasundaram Jayaraman
Hi Aman,
I guess the standby supervisor is going into rommon mode, with the standby in unknown state can you console into the standby supervisor and see whether it is in rommon?
If the supervisor is in rommon,
Issue "set" command and see what is the boot variable set in rommon.
In order to clear the bootvariable, type "BOOT=" in rommon prompt
In order to set the boot statement, "BOOT=bootflash:
To change the config register in rommon, confreg
Hope this helps
Cheers
Somu
Rate helpful posts
Hi Somu,
Thank you for your reply, actually when this slavesupervisor is in unknown state then, it is unable to access. It may be got hang. There is no display on console as well.
Aman
As i noticed, I found the below error message on console:
RnD-CoreSwitch#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
00:03:12: %CHKPT-3-TRANSMIT_FAILED: Checkpointing message transmission failure (timeout)
-Traceback= 10AAF994 10AB0880 10AABDC0 10AAC2B0 11C3AB58 10AB168C 10AB1704 11B86A8C 101D22A0 101D1594 11BEAA88 11BEAB04 101CEC8C 101CEEE8 101CF134 11B87544
00:03:12: %CTS_HA_ISSU-3-SEND_NEGO_FAILED: CTS HA ISSU client failed to send negotiation message. Error: 6 (ISSU_RC_CLIENT_ENTITY_DOES_NOT_EXIST_IN_PEER)
00:03:12: %ISSU-4-FSM_INCOMP: Version of local ISSU client ISSU CTS HA Client(2132) in session 65 is incompatible with remote side.
00:03:12: %CTS_HA_ISSU-6-INCOMPAT: CTS HA ISSU client negotiation results incompatible
00:04:23: %XDR-6-XDRIPCNOTIFY: Message not sent to slot 2 because of IPC error timeout. Disabling linecard. (Expected during linecard OIR)
RnD-CoreSwitch(config)#int Config mode locked out until standby initializes
configuration mode locked.'Please try later.'
Kindly advise
Aman
Hi, Aman.
I have the same symptoms.
Isn't there person know a solution?
I will wait for a reply.
