Cat 6500 boot problem
octroncisco
Community Member
I’m having problems with a Catalyst 6500 with two WS-SUP720 supervisors. When I try to boot the supervisors up, they show these messages:
11:47:29.284 FW[Mod 06]: sso_set_reg: ERR sso 2: reg 0x05 value 0x08 rc 0x80
11:47:29.284 FW[Mod 06]: sso_set_reg_direct: ERR sso 2: reg 0x47 value 0xA0 rc 0x80
11:47:29.284 FW[Mod 06]: sso_set_reg: ERR sso 2: reg 0x04 value 0x01 rc 0x80
*** System received a Software forced crash ***
signal= 0x17, code= 0x24, context= 0x44ae0504
  PC = 0x41d73e94, SP = 0x4309e108, RA = 0x4106fad8
  Cause Reg = 0x00003820, Status Reg = 0x34008002
rommon 1 >
and the IOS doesn’t start (I’m returned to the ROMmon prompt).
Before these messages, it appears this one:
Warning: Rommon NVRAM area is corrupted. Initialize the area to default values
For this reason, I’ve rebooted the supervisor with the “confreg 0x2142” and this message doesn’t appear again but I’m having the sames problems with SSO errors.
I tried to boot with another IOS image from the flash memory but It didn’t solved the problem.
I don’t think that is a hardware problem because I have the same problem with the two supervisor engines.
The output of the context command is:
rommon 4 > context
context: kernel context is not valid
Does anybody know a possible cause of this incident?
Thanks in advance,
5 Replies 5
Giuseppe Larosa
Hello octron,
have a look at following document
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a008015bfa1.shtml
being SSO the redundancy strategy I would try with only one supervisor inserted in the chassis to see what happens
Hope to help
Giuseppe
I had a similar issue a few months ago, turned out to be a corrupt flash file system.
Try booting with just 1 sup720 installed. If it boot ok try the other on it's own.
If you get on up ok insert the flash card into the extra slot and format it, then squeeze it. After that copy the IOS image from the good one to the newly formatted card.
Work for me.
Hello robins,
With only one supervisor It doesn't boot either.
Best regards,
octroncisco
Community Member
Helo Giuseppe,
Thank you for the info.
I've tried to boot the supervisor engine following that document (booting with an IOS image from a compact flash) but I have the same problem. With only one supervisor It doesn't boot either.
Best regards,
If you read through the document
This describes how you can recover from corrupt/lost IOS image (stuck in rommon) or how to recover if you have a corrupt/lost bootldr image file.
I guess if you are stuck in rommon you have check that there is a bootldr file present with the "set" command and tried to force a the Sup to load with the "boot" command.
If you have a corrupt IOS image file that will not boot then you can tftp a new image down from rommon, if the bootldr is lost then it needs to be replaced with a new image file via xmodem. Takes a little while though.
