cat 6500 Distributed EtherChannel
edgarfc254
I have configured an ether channel across two line cards on a cat6500 to connect to 4 NICs on an IBM VM server. For some reason traffic is not follow through the portchannel, but the same configuration works on a C3750.
I also get this message on the cat6500, which I am not sure are linked to the problem I am having.
Mar 26 06:16:07: FEC: pagp_is_idb_in_port_channel: Te1/1 has no subblock
Mar 26 08:06:02: FEC: pagp_switch_is_in_port_channel: Gi11/10 is not part of any agport
I wonder why I am geting the 2nd msg when the port is not configuare to be part of a port channel
Hieu Cao
Level 4
Level 4
Have you tried configuring the etherchannel to use LAcP instead of PAgP?
I have tried all the different combinations. The restriction is on the server side as it uses a vitual switch, it supports Etherchannel only (that is the that works).
C3750's config is as follows;
interface Port-channel3
description ISIS
switchport access vlan 113
switchport mode access
end
interface GigabitEthernet3/0/4x
description ISIS
speed 100
duplex full
channel-group 3 mode on
end
Port-channel: Po3
Age of the Port-channel = 11d:17h:23m:33s
Logical slot/port = 10/3 Number of ports = 4
GC = 0x00000000 HotStandBy port = null
Port state = Port-channel Ag-Inuse
Protocol = -
Ports in the Port-channel:
Index Load Port EC state No of bits
0 00 Gi3/0/41 On/FEC 0
0 00 Gi3/0/42 On/FEC 0
0 00 Gi3/0/43 On/FEC 0
0 00 Gi3/0/44 On/FEC 0
Time since last port bundled: 08d:19h:02m:28s Gi3/0/44
Time since last port Un-bundled: 08d:19h:02m:29s Gi3/0/44
