Hello and greetings.
I have an older Cat 6500 switch with an MSFC. I am required to erase all configs on the switch. I would like to know if there's any sequence of actions I need to follow. For, I have run the command 'clear config all' on the switch. Now, I am not able to access and erase the configs on the MSFC. I have to clear the configs on MSFC. So, given the scenario, how can I best erase the configs on the MSFC? I attempted 'session 15' and other session commands -but not able to erase. (err msg: module not found)
Any help . suggestions / links will be much apreciated!
thanks,
kishan
