06-08-2013 01:56 PM - edited 03-07-2019 01:47 PM
HI,
When i power on my cat 6506E with a sup720-3B, it stops on
ROMMON 1>
I have to type: boot before it start loading, without typing load, it can not
loas on its own.
Could you hepl please.
Solved! Go to Solution.
06-09-2013 07:19 PM
Here are the steps:
rommon 1 > dev
rommon 2> Set
rommon 3> confreg 0x2102
rommon 4> sync
rommon 5> reset
rommon 6 > dir slot0: >>> Beliving that you have image on the slot0 ((the device ID is slot0: and/or slot1:, corresponding to the PCMCIA cards inserted in the respective slots):
rommon 7> boot slot0:c7200-ik8s-mz.122-10b.bin >>> boot the respective image which you see under slot0/disk0
After this the device should boot with valid image and comes up without any issue.
Ref: http://www.cisco.com/en/US/products/hw/routers/ps359/products_tech_note09186a00800a750e.shtml
REgards
Inayath
06-08-2013 02:05 PM
Check your boot variable. When the switch boot all the way, do "sh boot"
You may have to set your boot variable
config t
boot system bootflash.....
Also, can you post "sh ver" and sh run?
06-08-2013 02:17 PM
Can you write down all the config line please?
06-08-2013 02:29 PM
Config t
boot system flash sup-bootflash:
Can you post sh boot and sh ver?
06-09-2013 08:53 AM
06-09-2013 09:23 AM
Can you issue these commands save and then reload:
config t
no boot system
boot system sup-bootdisk:s72033-advipservicesk9_wan-mz.122-33.SXI3.bin
exit
wr
reload
06-09-2013 12:55 PM
Could you show clearly the different steps of that confguration please ?
06-09-2013 03:03 PM
What do you mean by "clearly the different steps"?
just login to the switch and follow the commands I provided. If the switch is in production, you have to do this after hours, because rebooting will cause outage. Is this in production or lab?
06-09-2013 07:19 PM
Here are the steps:
rommon 1 > dev
rommon 2> Set
rommon 4> sync
rommon 5> reset
REgards
Inayath
06-10-2013 04:39 AM
there is no PCMCIA card inserted in the Super Engine.
What can i do then.
BR
06-10-2013 04:43 AM
Then no way. USB ports are not enabled for this module I bleieve.
You need to get the compact flash from one of the working device and boot it.
Inayath
06-14-2013 10:14 AM
Hi Sharief,
I very glad to let you know the it works.
Many Thinks
