Bookmark
Subscribe
604
Cat 6807 Platform QoS on Etherchannel
ewilkinson
We have migrated from a 6500 to a 6807 switch and I have the platform qos trust cos command under the Port Channel interfaces but when I show queuing on the interfaces in the channel they show as trust DSCP and I am seeing lots of Cos Changes under the show platform qos command.
I am unable to put the command directly on the interfaces that are in a ether channel already but if I put it on an interface and then join it to a channel it then shows as turst cos under the interface
As the switch is live I can't really remove interfaces to change the config, should it work correctly with the command under the ether channel only?
0 Replies 0
