cat os disable interface configuration
Mary
in cat os 6.3, can any one help the command to  display interface  E2/3 all configuration, how to default and disable the port
Julio E. Moisa
- Try show port 2/3 or show interface e2/3
- To disable -> Set Port 2/3 disable
- Not sure about default but try with: set default port 2/3
Please rate the comment if it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
not correct, show port 2/3 show the status, i want to know the configuration to port 2/3?
also set default port no such command, how to remove config of port 2/3?
in port 3/4, we set  port 3/4 belongs to vlan 123, vlan 123 has other five ports. how to remove port 3/4 from vl 123 only?  do we need to set module name 3, since port 3/4 and port 2/3 are in different module
Dear Experts,
My goal is to view current port 2/3 all configuration, then remove them all, it is very easily in IOS, but in cat OS, I have no idea. can anyone help
