module change in ws6500 switch
Mary
how to reset/reload module 1 ? and how to find between which interface port is module 1 located? thanks
12 Replies 12
Austin Sabio
Level 4
Level 4
  • To reload a specific module
hw-module module module_# reset
  • To verify module status
show module
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-6500-series-switches/24053-193.html
I hope this helps. Good luck!
Hi, thanks, the switches are connected through VSS, local switch number 2, peer switch number 1, currently I am in number 2, so how to reset module 1 in switch number 1 only?
Once you identify the faulty one---- vss# show module switch all
you should be able to reseat it----vss#hw-module switch # module # reset
http://www.cisco.com/c/en/us/td/docs/ios/vswitch/command/reference/vs_book/vs_01.html
http://www.cisco.com/c/en/us/td/docs/ios/vswitch/command/reference/vs_book/vs_02.html
any pre-check needed before we reset module? if I did reset after business hours, are there any risk factor I need to take into consideration before I run reset command? (i.e, how risky to run such command against production switch)
in the VSS environment, I have only one management IP, everytime I login, the local switch number is 2, but we want to reset module on switch number 1, so how to jump to local switch number 1 and do the reset, I don't want to reset in the wrong switch
to initiate commands on your 1st switch from 2nd switch you can use this
remote command switch 1 ........
resetting module only effects the module itself nothing else on the switch
whats your reason for resetting it , do you see an error in the module output
you could run diag if you want but if your resetting it no point really
diagnostic start switch 1 module 1
Hi Mark,
is local switch 1 and switch 2 in VSS shares same IP
in local switch 2, I enter below:
ZSW001#switch 1, but it said invalid input
if I want to reset slot 2 module 5, if  i enter:
hw-module module 5 reset, it applies to which slot?
if it applies to slot 1, how to enter the command to apply reset to slot 2?
Yes its same logical IP  as its VSS but when you login you can do show
sh switch virtual........see which switch you are
xxxxxxxxxx#sh switch virtual
Switch mode                  : Virtual Switch
Virtual switch domain number : 100
Local switch number          : 1
Local switch operational role: Virtual Switch Active
Peer switch number           : 2
Peer switch operational role : Virtual Switch Standby
sh module switch 2.. this will show you the mods on switch 2
Then to send a command to that switch you do
remote command switch x hw-module module x
You MUST use the remote command to reload a module in the other switch if you don't it will reload the switch module your currently logged into , check the show switch virtual first
If you want to login to the second switch from the 1st use this
xxxxxxx#remote login standby
Trying Switch ...
Entering CONSOLE for Switch
Type "^C^C^C" to end this session
once i remote login to switch 2, i can't use show switch virtual, so how to prove it is switch 2?
my another question is:
if it applies to slot 1, how to enter the command to apply reset to slot 2 module 5 only?
Theres only ever 2 switches in a VSS you cant remote in anything else from there only the other switch .show switch virtual shou;ld show you your logged into 1 as its local
I don't get the slot bit , its just module when your on cli reloading , the switch doesn't know slots just the number tied to the module , so below if I wanted to reload one of my VSS modules say 4 I would just use
hw-module module 4 reset
If I wanted to reload module 4 in switch 2
remote command switch 2 hw-module module 4
xir-b100cos01#sh mod
Mod Ports Card Type                              Model              Serial No.
  1    4  CEF720 4 port 10-Gigabit Ethernet      WS-X6704-10GE
  2    4  CEF720 4 port 10-Gigabit Ethernet      WS-X6704-10GE
  4   48  CEF720 48 port 1000mb SFP              WS-X6748-SFP
  5    5  Supervisor Engine 2T 10GE w/ CTS (Acti VS-SUP2T-10G
  7   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX
  8   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX
when you use ...remote login standby
you can run a show mod and you will see the serial numbers for the modules are different than the chassis you just came from , that will prove you moved into the other switch
Hi Mark,
the issue here is if I remote login to switch 2, in switch 2, i can't use hw-module module 4 reset, no such command, you can only use hw-module module 4 boot.
so it is not correct.
thus i 'm thinking in switch 1 (local switch), i use hw-module switch 2 module 4 reset.
pls share your opinion
Yes that's correct use the hw-module switch 2 .... if remote command doesn't have the hw-module syntax available , it depends on your sup and software what exact syntax is there for you but that is perfectly fine once your directing it at the second switch and your in switch 1 local when you login
when i run reset for module 1, all interface G1/1/1-G1/1/12 will be down, also G2/1/1-G2/1/15, G3/1/1-G3/1/18 will be down right? then after I run in switch 1 against switch 2, how to prove that i have reset (any evidence)
