Cat3750 - Deleting a directory in flash
Robert Ho
hey all, no luck in deleting a directory in flash. yet, all the contents in that directory has already been deleted. tried using the /force option as well but no go. i know i am missing something small. thanks for the help.
AIPA-3750#dir
Directory of flash:/
2 -rwx 976 Mar 4 2009 16:42:23 -10:00 vlan.dat
3 -rwx 1048 Mar 4 2009 16:52:54 -10:00 multiple-fs
4 -rwx 46 Mar 4 2009 16:52:54 -10:00 private-config.text
391 drwx 64 Mar 10 2009 08:38:28 -10:00 c3750-advipservicesk9-mz.122-25.SEE4
5 -rwx 12233687 Mar 10 2009 08:43:28 -10:00 c3750-ipservicesk9-mz.122-50.SE.bin
390 -rwx 8681 Mar 4 2009 16:52:54 -10:00 config.text
15998976 bytes total (2645504 bytes free)
AIPA-3750#del
AIPA-3750#delete flash:/c3750-advipservicesk9-mz.122-25.SEE4
Delete filename [c3750-advipservicesk9-mz.122-25.SEE4]?
Delete flash:/c3750-advipservicesk9-mz.122-25.SEE4? [confirm]
%Error deleting flash:/c3750-advipservicesk9-mz.122-25.SEE4 (Is a directory)
AIPA-3750#delete /force flash:/c3750-advipservicesk9-mz.122-25.SEE4
AIPA-3750#
AIPA-3750#
Leo Laohoo
Try the following:
delete /force /recursive flash:c3750-advipservicesk9-mz.122-25.SEE4
Hope this works.
pvezina
To delete a directory in a 3750 you have to type:
rmdir [directory]
This should work.
Patrick
Leo Laohoo
Try the following:
Hope this works.
good deal, i knew it was something small like that. thanks again for the help!
Thanks for the rating, Robert.
