CAT3850 Validate QoS Setting
Heriberto Diaz
 Does anybody know what command can I use to validate the QoS Setting on Cat3850? Because on IOS Cat2960X I can use the command "show mls qos".
I need to check if the 3850 have enable or disable the Rewrite DSCP.
Thanks and regards.
Giuseppe Larosa
Hello Heriberto,
Cat3850 used modular QoS like software based routers.
So you need to check if a policy map is applied to an interface with
show policy-map interfave gix/y
see the following link
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/3se/qos/configuration_guide/b_qos_3se_3850_cg/b_qos_3se_3850_cg_chapter_011.html#concept_1B88D96BE633433893CBB45C29EAC6BE
and the trust device command in interface mode can be used to trust DSCP or CoS bits but they need to be present in incoming frames
>>The trust device device_type command available in interface configuration mode is a stand-alone command on the switch. When using this command in an AutoQoS configuration, if the connected peer device is not a corresponding device (defined as a device matching your trust policy), both CoS and DSCP values are set to "0" and any input policy will not take effect. If the connected peer device is a corresponding device, input policy will take effect.
Hope to hep
Giuseppe
Giuseppe Larosa
Hello Heriberto,
Hope to hep
Giuseppe
the 3850 runs MQC as opposed to the older MLS. Check the link below for a comparison and the command equivalents:
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-3850-series-switches/118629-technote-qos-00.html
