Cat4K6 problem
volyashevsky
Community Member
Intermittent communication problems on different port including one of the gbic uplinks (had to disable) on sup
CATOS 7.2(1)
1 WS-X4013
2 WS-X4148-RJ
3 WS-X4148-RJ
4 WS-X4148-RJ
5 WS-X4148-RJ
6 WS-X4232-GB-RJ
Every 10 mins logging the following:
2009 Jan 15 12:46:18 Eastern -05:00 %SYS-4-P2_WARN: 1/Astro(3/6) - consecutive m
anagement requests timed out.
2009 Jan 15 12:46:19 Eastern -05:00 %SYS-4-P2_WARN: 1/Astro(6/4) - consecutive m
2009 Jan 15 12:46:20 Eastern -05:00 %SYS-4-P2_WARN: 1/Astro(3/2) - consecutive m
2009 Jan 15 12:46:22 Eastern -05:00 %SYS-4-P2_WARN: 1/Astro(3/5) - consecutive m
Thank you
mvsheik123
Level 11
Level 11
The supervisor loosing communication with component on line card. Check this link..
http://www.cisco.com/en/US/products/hw/switches/ps663/products_tech_note09186a00801434de.shtml#subtopic1n
Look for:
"%SYS-4-P2_WARN: 1/Astro(mod/port)" Section
Module might need replacement.
hth
MS
Giuseppe Larosa
I agree here the result of error message decoder
3. %SYS-4-P2_WARN: 1/Astro(mod/port) The switch is generating %SYS-4-P2_WARN: 1/Astro(6/6)... messages.
This error message indicates that the Supervisor Engine has lost communication to a component on a line card. The Supervisor Engine keeps track of any timeouts that are associated with this communication.
Recommended Action: There are many possible causes associated with this condition. For more information on this error message and possible causes, refer to http://www.cisco.com/en/US/products/hw/switches/ps663/products_tech_note09186a00801c9221.shtml
Hope to help
Giuseppe
glen.grant
A lot of times this is caused when someone introduces a loop on the switch and ties up the supervisor so long that it can't talk to the linecards . Seeing its on more than 1 card I would suspect that . Check for loops . Do a show proc cpu , usually cpu will also be very high if this is happening and telnet access to switch will be slow . Doa show cdp nei and see if the switch sees "itself" on more than 1 port indicating a looped port . If you see this shutdown one of the ports which will break the loop and normalize the cpu . That being said it could still be a supervisor .
