CAT6500 does not display config
ronshuster
any idea what this means?
coresw#sh run
Unable to read configuration. Try again later
the CPU of the 6500 is very low.
5 Replies 5
Giuseppe Larosa
Hello Aaron,
there can be another telnet/ssh session where a sh run has been given and the session is stucked at a more prompt.
check with sh users if there are other sessions.
There is an option that provides exclusive access to running config.
Hope to help
Giuseppe
I am not sure this is the problem as now I can see the config but it can take a few minutes until it pops up on the screen. The switch was rebooted 2 days ago.
Hello Aaron,
as noted by Leo you may be hitting a SW bug.
To help narrow the search more details are needed, if you can attach a sh ver and sh module
Hope to help
Giuseppe
Leo Laohoo
Hi Aaron,
What's your IOS? Sounds like you've just hit an IOS bug.
Hope this helps.
IOS (tm) s72033_rp Software (s72033_rp-IPSERVICESK9-M), Version 12.2(18)SXF7, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Thu 23-Nov-06 06:50 by kellythw
Image text-base: 0x40101040, data-base: 0x42D98000
ROM: System Bootstrap, Version 12.2(17r)SX5, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-IPSERVICESK9-M), Version 12.2(18)SXF7, RELEASE SOFTWARE (fc1)
coresw uptime is 2 days, 5 hours, 53 minutes
Time since coresw switched to active is 2 days, 5 hours, 53 minutes
System returned to ROM by power cycle (SP by power on)
System restarted at 06:25:06 EDT Sun May 31 2009
System image file is "sup-bootflash:s72033-ipservicesk9-mz.122-18.SXF7.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6509-NEB-A (R7000) processor (revision 1.2) with 458720K/65536K bytes
of memory.
Processor board ID FOX1022088D
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
SuperLAT software (copyright 1990 by Meridian Technology Corp).
X.25 software, Version 3.0.0.
Bridging software.
TN3270 Emulation software.
6 Virtual Ethernet/IEEE 802.3 interfaces
122 Gigabit Ethernet/IEEE 802.3 interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
