Cat6500 Sup1A password recovery problem.
era_cisco
Dear All,
I have an unpleasant issue with password recovery in 6500 Sup1A-2G.
I very carefully read password recovery procedure,
http://www.cisco.com/en/US/products/hw/switches/ps708/products_password_recovery09186a00801349aa.shtml#ouput
reset power, successfuly get in Console>(Enable) mode, but then I tried to set new password,
I receive following message:
Enter password:
Console>
Console> en
Enter password:
Console> (enable)
Console> (enable) set enablepass
Command disabled until the system config file is uploaded.
Console> (enable) 2012 Nov 24 10:30:09 PDT -07:00 %SYS-5-MOD_OK:Module 1 is online
2012 Nov 24 10:30:09 PDT -07:00 %SYS-5-MOD_OK:Module 4 is online
2012 Nov 24 10:30:09 PDT -07:00 %SYS-5-MOD_OK:Module 3 is online
Console> (enable)
Console> (enable)
Console> (enable) 2012 Nov 24 10:30:22 PDT -07:00 %SYS-5-SUP_IMGSYNC:File synchronization process will start in 10 seconds
Console> (enable)
Console> (enable)
Console> (enable)
Console> (enable) show run
TFTP session in progress. Try again later.
Console> (enable) 2012 Nov 24 10:31:23 PDT -07:00 %MGMT-5-SYS_CONFIG_START:System config started with NVRAM text configuration file
2012 Nov 24 10:31:24 PDT -07:00 %SYS-5-PORT_SSUPOK:Ports on standby supervisor (module 2) are up
2012 Nov 24 10:31:24 PDT -07:00 %SYS-3-MOD_PORTINTFINSYNC:Port Interface in sync for Module 2
2012 Nov 24 10:31:24 PDT -07:00 %MGMT-5-SYS_CONFIG_END:System config ended
2012 Nov 24 10:31:24 PDT -07:00 %SYS-5-AUTOSAVE:auto-save timer started
Enter old password:
Sorry password incorrect.
Enter old password:
Console> (enable)
Console> (enable)
Console> (enable) 2012 Nov 24 10:31:44 PDT -07:00 %SYS-5-SUP_IMGSYNCSTART:Active supervisor is synchronizing slot0:cat6000-supk8.8-1-1.bin
Console> (enable)
Console> (enable)
Console> (enable)
Enter old password:
Console> (enable)
Console> (enable)
Console> (enable)
I'm in doubt, becouse my config haven't any string about tftp.
Could you help me?
Thanx in advance.
See config bellow:
set password <HASHXXXXXXXXXXXXXXXXXXXXXXXX>
set enablepass <HASHXXXXXXXXXXXXXXXXXXXXXXXX>
set logout 0
set config mode text nvram
set config mode text auto-save enable
set config mode text auto-save interval 360
#vtp
set vtp domain bms
set vtp mode transparent vlan
set vtp version 2
set vlan 7 name nwzbms type ethernet mtu 1500 said 100007 state active
set vlan 30 name video_security type ethernet mtu 1500 said 100030 state active
set vlan 31 name novinsky_31 type ethernet mtu 1500 said 100031 state active
set vlan 1002 name fddi-default type fddi mtu 1500 said 101002 state active
set vlan 1004 name fddinet-default type fddinet mtu 1500 said 101004 state active bridge 0x0 stp ieee
set vlan 1005 name trbrf-default type trbrf mtu 4472 said 101005 state active bridge 0xf stp ibm
set vlan 1
set vlan 1003 name trcrf-default type trcrf mtu 4472 said 101003 state active parent 1005 ring 0xccc mode srb aremaxhop 7 stemaxhop 7 backupcrf off
#ip
set interface sc0 1 192.168.3.65/255.255.255.0 192.168.3.255
set interface sc1 down
set ip route 0.0.0.0/0.0.0.0         192.168.3.43
set ip alias default         0.0.0.0
#ntp
set timezone PDT -7 0
#set boot command
set boot config-register 0x2102
set boot system flash slot0:cat6000-supk8.8-1-1.bin
# default port status is enable
#module 1 : 2-port 1000BaseX Supervisor
#module 2 : 2-port 1000BaseX Supervisor
#module 3 : 16-port 1000BaseX Ethernet
set trunk 3/3  on dot1q 1-1005,1025-4094
set trunk 3/8  on dot1q 1-1005,1025-4094
#module 4 : 8-port 1000BaseX Ethernet
#module 5 empty
#module 6 empty
#module 15 empty
#module 16 empty
end
amikat
Will you please set the configuration mode to binary model (which is the default) when successfully at the "Console>(enable)" prompt via the "set config mode binary" command and then re-try the password recovery procedure as for the document quoted.
Best regards,
Antonin
amikat
Best regards,
Antonin
