Cat6506-E Tracebacks and Syslog Messages
Customer use Cat6506-E with VS-SUP2T-10G and IOS Release 15.1(2)SY3, Image is IPService.
Now we get following Syslogs back:
Dec 20 03:42:28.539 MET: EU_LIFSTAT: lifstat_read_counter(): Parity error detected in EARL 0 at idx 0x46D7 high [0x0] mid [0x8000] low [0x0]
Dec 20 03:42:28.539 MET: -Traceback= 76879D4z 76D6880z 76D91E8z 76D9340z 76DB1D4z 76DBC04z 6DF38B4z 6DECE98z
Feedback will be appreciate.
Hansruedi
rakeshvelagala
Level 3
Level 3
You are using Multicast?  You are getting these alerts continuously?
For Trackbacks, usually Cisco has a tool to decode and check if you are encountering certain bug.
rakeshvelagala
Level 3
Level 3
This indicates Parity error.
Did the module reload?
->if the traceback is not repeated you can safely ignore it.It could be soft parity error ie. transient or one time occurrence.
Naveen
***rate if it is helpful***
