11-29-2008 02:58 AM - edited 03-06-2019 02:43 AM
Hi Netpro,
i am stuck in Rommon , my cat6 can not bootup. need your advice .
thanks.
regard
jack
11-29-2008 03:10 AM
Get a suitable IOS from Cisco and boot from tftp which could be your laptop
http://www.cisco.com/en/US/products/hw/switches/ps663/products_tech_note09186a00800949c3.shtml
11-29-2008 07:32 AM
Hi Jack,
Where you doing some thin when it got into rommon.
I assume it is running hybrid IOS ,so is it rommon of SP or RP.
Give configregister value 0x2102 and reset.
Chao
Vishwa
11-29-2008 08:29 PM
Hi Vishwa,
this is sup 720 whereby someone itchy hand loaded wrong ios therefore causing switch cant boot up.
your reply will be highly appreciated.
thanks.
regards,
jack
11-29-2008 10:11 PM
12-01-2008 02:34 AM
Hi Viyuan,
thanks for your doc. it was really helpful but i dont know why ? after new ios loaded and boot path have been setup as well. somehow when i reload , it's went back to Rommon 1> again. :(
thanks.
jack
12-01-2008 08:33 AM
Hi Jack,
Can u please post the message it gives u before Rommon1 prompt
