Dear all
I am facing this problem for the first time and the internet does not provide too much help about this one:
Here is a 6509 with Sup720-3BXL/MSFC3. It begins to load its image but then sits in an endless loop of
Waiting (slot 5) for supervisor to come online in other slot. iteration = 31
Next Retry will be done after 6 seconds
All I can find on the web here is a hint regarding the modular software image (...-mz...) which cannot be used. But I have never used other ones than these mz-ones.
I tried to boot different images from the rommon but the result is always the same.
I guess there is some simple solution for this.... but what is it?
Grischa
Additional note: The system booted normally before the rommon-upgrade to 8.5.4.
Have you solved that?
Thank you,
