12-26-2018 12:55 AM - edited 03-08-2019 04:53 PM
i have migrated the configuration from C3750 to cat9300 and i want to configure below configuration under the interface " power inline consumption 8000" but this command not supported , what is the equivalent command on Cat9300.
Solved! Go to Solution.
12-26-2018 02:09 AM
here is the command :
interface gi 0/0
power inline port priority high ---"Sets the power priority of the port. In case of a power supply failure, ports configured as low priority are turned off first and ports configured as high priority are turned off last. The default priority is low.
here is the reference :
12-26-2018 02:09 AM
interface gi 0/0
12-26-2018 03:38 AM
Hi Balaji,
Thanks a lot.
