Cat9300P-E 2 TwentyFiveGig not appeared after upgrade to Everest recommended Image
Steev112
 I have CAT9300 switches after upgrading to "cat9k_iosxe.16.06.04a.SPA.bin: it gave me these error.
interface TwentyFiveGigE1/1/1
% Invalid input detected at '^' marker.
interface TwentyFiveGigE1/1/2
13 Replies 13
marce1000
 - Follow the boot process on a console link after the upgrade, check for errors. Also just after the switch has booted issue show logging ; check if you can find more info concerning your problem.
M.
Hi Marce,
i have followed upgrade procedure as follows:
request platform software package install switch all file flash:cat9k_iosxe.16.06.04a.SPA.bin auto-copy
install add file flash:cat9k_iosxe.16.06.04a.SPA.bin activate commit
reload
Can you downgrade the firmware and see if the TwentyFiveGig interface returns or not?
The image was "16.8.1r" and i installed the recommended image.
do you want me to use that image.
I know the reason why: Is there a 25 Gbps interface module (C9300-NM-2Y) installed?
Hi Lea,
below is the show inv:
NAME: "c93xx Stack", DESCR: "c93xx Stack"
PID: C9300-48P , VID: V02 , SN: FOC2238Q051
NAME: "Switch 1", DESCR: "C9300-48P"
NAME: "Switch 1 - Power Supply A", DESCR: "Switch 1 - Power Supply A"
PID: PWR-C1-715WAC , VID: V03 , SN: LIT223526E4
NAME: "Switch 1 FRU Uplink Module 1", DESCR: "8x10G Uplink Module"
PID: C9300-NM-8X , VID: V01 , SN: FOC22352AWC
Hi Leo.
do you know what is the issue?
I think I know what the issue is.
The switch is a 9300-48P.  This means it is a 48 port triple speed ethernet.  There is a C9300-NM-8X module.  This module only supports SFP+.  Nowhere in the "sh inventory" does it say the switch has C9300-NM-2Y (2 x 25 Gbps ports).
 - You are not replying to my questions.
M.
Below is the show logging:
Switch#show logging
Syslog logging: enabled (0 messages dropped, 5 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
Console logging: level debugging, 55 messages logged, xml disabled,
filtering disabled
Monitor logging: level debugging, 0 messages logged, xml disabled,
filtering disabled
Buffer logging: level debugging, 59 messages logged, xml disabled,
filtering disabled
Exception Logging: size (4096 bytes)
Count and timestamp logging messages: disabled
File logging: disabled
Persistent logging: disabled
No active filter modules.
Trap logging: level informational, 61 message lines logged
Logging Source-Interface: VRF Name:
Log Buffer (4096 bytes):
e correctly understood
*Dec 26 08:46:57.958: %SYS-5-CONFIG_I: Configured from memory by console
*Dec 26 08:46:58.125: %SYS-5-RESTART: System restarted --
Cisco IOS Software [Everest], Catalyst L3 Switch Software (CAT9K_IOSXE), Version 16.6.4a, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Fri 26-Oct-18 18:15 by mcpre
*Dec 26 08:46:58.156: %SSH-5-ENABLED: SSH 1.99 has been enabled
*Dec 26 08:46:58.305: %HMANRP-6-HMAN_IOS_CHANNEL_INFO: HMAN-IOS channel event for switch 1: EMP_RELAY: Channel UP!
*Dec 26 08:46:58.306: %HMANRP-6-EMP_NO_ELECTION_INFO: Could not elect active EMP switch, setting emp active switch to 0: EMP_RELAY: Could not elect switch with mgmt port UP
*Dec 26 08:46:59.050: %LINK-5-CHANGED: Interface GigabitEthernet0/0, changed state to administratively down
*Dec 26 08:47:00.011: %LINK-3-UPDOWN: Interface GigabitEthernet1/1/1, changed state to down
*Dec 26 08:47:00.012: %LINK-3-UPDOWN: Interface GigabitEthernet1/1/2, changed state to down
*Dec 26 08:47:00.012: %LINK-3-UPDOWN: Interface GigabitEthernet1/1/3, changed state to down
*Dec 26 08:47:00.013: %LINK-3-UPDOWN: Interface GigabitEthernet1/1/4, changed state to down
*Dec 26 08:47:00.013: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/1/1, changed state to down
*Dec 26 08:47:00.013: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/1/2, changed state to down
*Dec 26 08:47:00.013: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/1/3, changed state to down
*Dec 26 08:47:00.013: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/1/4, changed state to down
*Dec 26 08:47:00.013: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/1/5, changed state to down
*Dec 26 08:47:00.013: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/1/6, changed state to down
*Dec 26 08:47:00.013: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/1/7, changed state to down
*Dec 26 08:47:00.013: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/1/8, changed state to down
*Dec 26 08:47:00.013: %LINK-3-UPDOWN: Interface FortyGigabitEthernet1/1/1, changed state to down
*Dec 26 08:47:00.013: %LINK-3-UPDOWN: Interface FortyGigabitEthernet1/1/2, changed state to down
*Dec 26 08:47:00.123: %LINK-3-UPDOWN: Interface Vlan1, changed state to up
*Dec 26 08:47:01.018: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/1/1, changed state to down
*Dec 26 08:47:01.019: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/1/2, changed state to down
*Dec 26 08:47:01.019: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/1/3, changed state to down
*Dec 26 08:47:01.019: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/1/4, changed state to down
*Dec 26 08:47:01.019: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/1/1, changed state to down
*Dec 26 08:47:01.019: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/1/2, changed state to down
*Dec 26 08:47:01.019: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/1/3, changed state to down
*Dec 26 08:47:01.019: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/1/4, changed state to down
*Dec 26 08:47:01.019: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/1/5, changed state to down
*Dec 26 08:47:01.019: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/1/6, changed state to down
*Dec 26 08:47:01.019: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/1/7, changed state to down
*Dec 26 08:47:01.019: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/1/8, changed state to down
*Dec 26 08:47:01.019: %LINEPROTO-5-UPDOWN: Line protocol on Interface FortyGigabitEthernet1/1/1, changed state to down
*Dec 26 08:47:01.019: %LINEPROTO-5-UPDOWN: Line protocol on Interface FortyGigabitEthernet1/1/2, changed state to down
*Dec 26 08:47:03.862: %PNP-6-PNP_DISCOVERY_STOPPED: PnP Discovery stopped (Startup Config Present)
*Dec 26 08:47:23.121: %PLATFORM_PM-6-FRULINK_INSERTED: 8x10G uplink module inserted in the switch 1 slot 1
Switch#
Switch#
Leo Laohoo
What is the exact model of this switch?
Hi Leo,
This is the part number "C9300-48P-E".
WOLFGANG MEHLER
Hi Steev112,
Cisco 25GBASE SFP28 Modules C9300-NM-2Y is earliest supported within
IOS XE Fuji 16.9.1
Wolfgang
