Catalyst 1000 | monitor capture doesn't work data plane
NetworkingGeek1
Hello community,
Recently I bought Cisco Catalyst 1000 switch and now I'm playing with its features. I tried "monitor capture" feature, but for me it's working only for process switched packets, it can't capture CEF switched packets. All configuration for capturing CEF switched packets are there, but it simply doesn't work. Does anybody aware if it's some kind of limitation of that platform or maybe I don't apply correct config?:
monitor capture buffer BUF size 2048 max-size 1518 linear
monitor capture point ip cef POINT GigabitEthernet 1/0/1 both
monitor capture point associate POINT BUF
monitor capture point start POINT
M02@rt37
Hello @NetworkingGeek1
What is the IOS version, please?
Best regards
Hello M02@rt37  Originally IOS version was 15.2.7E4 and then I upgraded it to the latest 15.2.7E7. On both versions "monitor capture" feature behaves as I described above.
