Switch Stack Reload by Critical process crash.
Tinz
Hey everyone.
My switch stack 6 members reload by itself.
Switch model WS-C3650-48PD
running on version 16.12.07
Last reload reason on switch Critical process crash.
the system-report on switch show switches are crash with the error SXE-WATCHDOG: Process = SAStorage and A critical process linux_iosd_image has failed (rc 142).
I need to know what is linux_iosd_image has failed (rc 142).
Leo Laohoo
@Tinz wrote:
Process = SAStorage
SA = Smart (Licensing) Agent
And "linux_iosd_image" is usually used by telemetry and Cisco Smart Licensing.
That is the cause of the crash.
I would recommend raising a Cisco TAC case to confirm.
Leo Laohoo
@Tinz wrote:
Process = SAStorage
Thanks.
Mark Elsen
 - Consider using (upgrade) : https://software.cisco.com/download/home/284850622/type/282046477/release/Gibraltar-16.12.8  ,
 check if that can help ,
 M.
