[Catalyst 1000 Series] Flexlink Function
EZ17
Visitor
Hi all,
Currently, Catalyst 1000 Series with version 15.2(7)E not support Flexlink function, but does it support Flexlink+?
I've try to add Flexlink+ command on this model not success, the error display
Main port:
interface GigabitEthernet1/0/1
switchport mode trunk
switchport trunk allow vlan all
rep segment 1023 edge no-neighbor primary
Backup port:
interface GigabitEthernet1/0/2
rep segment 1023 edge no-neighbor preferred => can't do this command, the error below appear
Error: Segment id 1023 already has one edge no-neighbor port. Cannot configure another edge no-neighbor port.
balaji.bandi
Look at the configuration and Limitation :
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst1000/software/releases/15_2_7_e/configuration_guides/lyr2/b_1527e_layer2_c1000_cg.pdf
BB
