09-13-2024 06:36 PM
Hello, I would like to know if catalyst 1300 series support cross stack LACP,
regards.
09-13-2024 07:09 PM
According to the Catalyst SMB 1300 Data Sheet:
Support for IEEE 802.3ad Link Aggregation Control Protocol (LACP)
It is very important to check the configuration guide (if you can find it!) before making any decision.
09-13-2024 07:51 PM
@Jauffrey hi, can you explain the requirement. these switches are support LACP. what you mean by cross stack? if you build stack using 2 or more switches (same stack) you can create LACP using any member in the single stack.
09-30-2024 12:00 PM
Hello, I meant using 2 ports from 2 different switches in the same stack to make a LAG, this is not possible on this switch according to the answer I received on a cisco youtube video comment.
09-30-2024 12:14 PM
It appears the answer should be yes.
09-30-2024 04:19 PM
Hello Jauffrey!
The answer is: Yes. Up to 8 switches in stack.
