Catalyst 1300 Not deleting commands
abc1235
Hallo,
How can I delete a few commands from an interface? I am unable to do that, instead I get the error message below:
Test-CI1300#sh run int gi1
interface GigabitEthernet1
no switchport
switchport mode trunk
switcinterface GigabitEthernet0/1/3
switchport trunk allowed vlan 100,251,300,804-806,831,1831,2831
service-policy output WAN-EDGE-4-CLASS
hport access vlan 100
switchport trunk native vlan 100
switchport trunk allowed vlan 100,200
Test-999CI1300#conf t
Test-999CI1300(config)#int gi1
Test-999CI1300(config-if)#no switchport access vlan 100
% Wrong number of parameters or invalid range, size or characters entered
Thank you
KJK99
Level 3
Level 3
@abc1235
Try this
Note, there is no vid in it.
Kris K
8 Replies 8
Hi @abc1235
 If you want to remove a vlan from trunk you need to use
switchport trunk allowed vlan remove <xxx>
The command you use will work only in access interface not in trunk
balaji.bandi
no switchport
the port in trunk mode, that means all the VLAN allowed, there is no command to remove there.
or you may be looking to remove different port check the command do the correct port.
BB
Hi @balaji.bandi even with that the previous "switchport access vlan 100" is not deleted.
can you post the configuration again, show run to look what you doing there. what version code running ?
no switchport access vlan 100   < this this should work
reference config guide :
https://www.cisco.com/c/en/us/td/docs/switches/campus-lan-switches-access/Catalyst-1200-and-1300-Switches/cli/C1300-cli.html
BB
abc1235
Thank @Flavio Miranda I do not want this  port to be a L3 port, I'd like for it to be a trunk port, but while testing, I set it as an access port but now I can't relete it. I'm not even able to set the switch to default (default int x). I posted the wrong config, this is the correct one, that has both switchport access and trunk:
Sorry, see again my privious answer, I misunderstood your request
switchport trunk allowed vlan remove 100
KJK99
Level 3
Level 3
@abc1235
Try this
Kris K
Hi @KJK99 This has worked. Thanks so much
