ā01-27-2016 03:09 AM - edited ā03-08-2019 03:32 AM
Hi experts,
a customer of mine wants a 12 port Cisco switch (no PoE); I'm about to offer a 3560 Compact switch (WS-C3560CX-12TC-S) but I wonder if there is any difference between the "standard Catalyst" and the compact series. Obviously there is less ports and I guess less feature supported but is there any difference in the way they are managed ? For example the CLI is the same of standard Catalyst ?
There is something else to consider ?
Thank you for your help,
enrico
Solved! Go to Solution.
ā01-27-2016 03:11 AM
There basically the exact same , cli etc just less ports and less noisy for small offices never noticed any difference with them while configuring them
ā01-27-2016 04:12 AM
Thank you very much Mark
e
ā03-01-2016 08:50 AM
I was inquiring for the exact same reasons.
my only concern was end of sale at EOY. 2016
although remains supported 5 years out...
I good for now and Thanks Mark
Charlie
