Catalyst 2960-CX - Can't detect USB drive
HeKay
I'm trying to load a config file from a USB drive.
When I try to connect the USB Stick with the 2960 switch I get the following error:
%USB_HOST_STACK-5-USB_ENUM_FAIL_GETDESCR: Failed to enumerate a USB device as not able to read the device's description.
I've tried reformatting the drive multiple times (FAT32, NTFS both don't work) and I couldn't find any Information regarding this error.
Switch#show version
Cisco IOS Software, C2960CX Software (C2960CX-UNIVERSALK9-M), Version 15.2(7)E, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2019 by Cisco Systems, Inc.
Compiled Sat 23-Mar-19 09:05 by prod_rel_team
ROM: Bootstrap program is C2960CX boot loader
BOOTLDR: C2960CX Boot Loader (C2960CX-HBOOT-M) Version 15.2(6r)E, RELEASE SOFTWARE (fc1)
Switch Ports Model                     SW Version            SW Image
*    1 12    WS-C2960CX-8PC-L          15.2(7)E              C2960CX-UNIVERSALK9-M
12 Replies 12
Leo Laohoo
Get a different brand of USB flash drive.
Hi @Leo Laohoo ,
I've tried using a different brand, with no luck. The same drive works perfectly fine on a 9200 Switch.
Julio E. Moisa
Check the following link, try to use: usbflash1
https://m.blog.naver.com/PostView.naver?isHttpsRedirect=true&blogId=byunkook&logNo=221521143294
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Hi @Julio E. Moisa ,
I can't access this command, since the switch won't really detect the drive at all. The moment i plug the stick into the switch, i get the error mentioned above.
M02@rt37
Hello @HeKay,
As concerned FAT16 (<4Gb) was Ok on this Cisco SW model.
Best regards
HeKay
Hello M02@rt37 ,
I've just tried formatting the drive as FAT16, which doesn't work either. I get the same error.
I've also tried previously using the same Stick on a 9200 Switch, which was instantly detected and worked perfectly fine. So the drive itself works well.
Best regards
Ok @HeKay,
same USB on an other C2960 but an other IOS version ? Do you have that?
Best regards
Unfortunately not. I can't upgrade the version either, since the Switch won't accept any drives
HeKay
Further Update:
I've tried another drive from a different brand, formatted it to both FAT32 and FAT16 and both times i got the following error:
May 4 13:42:15.532: %USB_HOST_STACK-3-USB_FLASH_READY_TEST_FAILED: USB flash failed to pass 'Ready' test.
May 4 13:42:15.532: %USBFLASH-3-DEVSTARTSTOP: usbflash0 MSCD_StartStop failure in usbflash_mscd_scsi_listener!
Could it be possible that the Switch won't accept any drives above USB 2.0?
Yes @HeKay, it's possible ! You can test with a good one ?
Best regards
This means the USB flash is of a different "type".
Try a different brand and a different size.
This was probably the solution for me - switching from a "brand new" USB flash to an "older" one. I do not know exactly what USB version the two flashes I used had.
Maybe you could set this post as the solution?Just to make it even easier for others (including me) in the future.
Thanks!
