Catalyst 2960 for my LAN WS-c2960-48TC-S vs WS-c2960-48TC-L
leonard.docea
Hello
I want buy a Catalyst 2960 but i don't now which is great for my situation.
Model : WS-c2960-48TC-S (LAN Lite - 400 euro) vs WS-c2960-48TC-L (LAN Base - 900 euro) the difference of price is half.
I need 3 VLAN (2 VLANs with data  and other VLAN (3th only voice).All security options want applied on ports.(MAC,ACCESS..etc)
Between switch and router will be a TRUNK channel...
The network design parts: lan printers  - 4, desktop - 16, phone IP - 10.
I have only ISP .
So..what i need?      LAN Lite or LAN Base
Another question: In LAN Lite i have all commands?
thank's
michael o'nan
Level 4
Level 4
Sounds like the LAN Lite should fit all your needs.
But the last question ?
Q. What are the advantages of Cisco Catalyst 2960 Series Switches with the LAN Base software relative to Cisco Catalyst 2960 Series Switches with the LAN Lite software?
A. Cisco Catalyst 2960 LAN Base switches deliver intelligent services for branch offices and wiring closets. The LAN Base IOS software supports enhanced Layer 2+ security, quality of service (QoS), availability, and scalable management to enable new converged applications. Catalyst 2960 LAN Base switches include both 10/100 Fast Ethernet and 10/100/1000 Gigabit Ethernet connectivity in 8-, 24-, and 48-port configurations.
Cisco Catalyst 2960 LAN Lite switches are for entry-level branch office and wiring closet networks. They simplify the migration from nonintelligent hubs and unmanaged switches to a fully scalable and reliable network. The LAN Lite IOS software supports standard Layer 2 security, QoS, and availability while lowering the network total cost of ownership. Catalyst 2960 LAN Lite switches deliver 10/100 Fast Ethernet connectivity in 24- and 48-port configurations.
All Cisco Catalyst 2960 Series Switches have technical support service options available through Cisco SMARTNet ® service. All come with a Limited Lifetime Hardware Warranty, and LAN Base and LAN Lite software updates are provided at no additional cost.
Information came from the below link:
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-2960-series-switches/prod_qas0900aecd80322c37.html
Will all commands be available? No...if they were then what would be the point of having different software levels? Will the switch meet all basic to intermediate needs? Yes. If you are looking for a set of specific commands to see if they are available then check out the command reference tools available from Cisco.
http://www.cisco.com/c/en/us/support/switches/catalyst-2960-series-switches/products-command-reference-list.html
