Hi All,
I have Catalyst 2960 Switch and I want to configure some ports to access limited UDP ports, nothing else.
for example: I want to restrict port 2, 4, 6 of my switch, which can through only 5096 and 5097 UDP traffic.
Kindly help me in this regard.
if ports desired to be blocked belong to specific vlan(s), you can use vlan access-map :
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/15-0SY/configuration/guide/15_0_sy_swcg/vlan_acls.html#pgfId-1055968
Thanks for reply,
it means if I put net_5001 and net_5002 then all the other packets will be drop ?
