How to block specific mac address on specific port to block communication
asheesh.gupta11
Hi All
i want to block a specific user mac address to use an specific port .
i configured acl
#mac access-list ext block_pc
(config-ext-macl)#deny host <mac of pc> any
then
at port
#int gi<any port>
(conf port)#mac access-group block_pc
but its not working.
can you please help me to block the same.
8 Replies 8
balaji.bandi
Other option you can do is sticky mac, so only trusted device will be connected.
BB
Hi Balaji
i am already using radius by ISE server , but i want to block that mac only on a particular port not from all network
@asheesh.gupta11 wrote:
In that case port will not be used by any device ,i want to block only a particular mac address.
This means that ANYONE has access to that port?
Block using MAC-based ACL.
Leo Laohoo
1.  Shutdown the port; or
2.  Assign the port into VLAN 1.
Hi Leo
how about doing as below to block the MAC for the VLAN X
 mac address-table static xxxx.xxxx.xxxx  vlan  Y drop   <<--- replace xxx.xxxx.xxxx and Y as per your requirement.
test advise.
BB
Hello
mac access-list extended nomac
deny host xxxx.xxxx.xxxx any
permit any any
int x/x
mac access-group nomac in
Kind Regards
Paul
