Catalyst 2960-L Web UI missing header information
Mike-
The http server web interface header is missing information that would be nice to have.
The switch was like this during first log in.
I did update the IOS/Web UI to Release 15.2.7E3 but same results.
Here's a screenshot.
balaji.bandi
15.2.7E3  - Looks like a bug on this version, it does not affect the switch, but some GUI Code bugs, if you like without header information you can use it as expected to work. ( also worth try IE also? is that works )
15.2.7E2 - is the cisco suggested version - that should work as expected.,
BB
5 Replies 5
Mark Elsen
 - Check if this thread can provide useful hints : https://community.cisco.com/t5/switching/catalyst-2960-l-web-ui-broken/td-p/3878063
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
The link provided didn't exactly relate to my case, but I did downgrade to E2  (the previous release) and now the Web UI is a blank page.
Switch still works, web ui does not.
balaji.bandi
BB
The Header displays correctly in Internet Explorer. Does not work in chrome or firefox.
rasmus.elmholt
Level 7
Level 7
I have seen that problem before on a switch with the same software version, we had to take a step down to an older software to get around it.
The switch seems to work fine though. most likely this is just cosmetic
