12-07-2016 05:45 AM - edited 03-08-2019 08:29 AM
my 2960 is configured with management address 192.168.100.13 in valn1.
I need to access the management address through vlan 900
so I created vlan 900 and after I entered :
Interface Vlan900
ip address 192.168.100.250 255.255.255.0
but I get:
192.168.100.0 overlaps with Vlan1
I understand my error but How can I 'move' my management IP from valn1 to vlan900?
Thanks in advance
mb
Solved! Go to Solution.
12-07-2016 05:59 AM
Hi Balma,
If we are talking about an SVI then you should be able to go under vlan 1
UK--SW-SRV-01(config)#int vlan 1
UK--SW-SRV-01(config-if)#no ip address
Then put IP address under Interface Vlan 900
12-07-2016 05:59 AM
Hi Balma,
12-07-2016 06:24 AM
I'm connected in telnet to my management address, if I set NO IP ADDRESS to vlan1 I loose the telnet and I cannot put IP address under Interface Vlan 900...
Am I wrong?
12-07-2016 06:46 AM
I made (wrongly) the assumption you were local to the switch.
I think the 2960 will support multiple SVIs being up. You could configure a temporary SVI on a different subnet. Jump onto switch via the new SVI.
You would need to ensure you have routing in place I guess for this new address space.
A more riskier way would be to copy over the current startup config, amend it to suit your objectives and copy it back over. Reload the switch. I have never done this though so not sure how feasible it is.
Some of the more knowledgeable may be able to advise more.
12-07-2016 08:14 AM
I've done it using a serial connection.
