ā01-18-2013 05:35 AM - edited ā03-07-2019 11:10 AM
I have update the firmware of a Cisco Catalyst 2960S-48TS-L
from 12.2(58)SE2
to 15.0(2)SE1
and now the switch just keeps rebooting with error:
..done Initializing flashfs.
Checking for Bootloader upgrade..
Boot Loader upgrade not required (Stage 2)
%Software-forced reload
Buffered messages:
Queued messages:
Mar 30 01:27:39.903: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console de
bugging output.
*Mar 1 00:00:15.272: Read env variable - LICENSE_BOOT_LEVEL =
Mar 30 01:27:38.283: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name
= c2960s_lanbase Next reboot level = lanbase and License = lanbase
Mar 30 01:27:38.534: %CRYPTO-0-SELF_TEST_FAILURE: Encryption self-test failed (S
oftware self-integrity test)
Mar 30 01:27:38.802: %CRYPTO-0-SELF_TEST_FAILURE: Encryption self-test failed (R
BG: unable to initialize rbg)
Mar 30 01:27:38.802: %CRYPTO-0-SELF_TEST_FAILURE: Encryption self-test failed (S
P 800-90 DRBG)
: Unexpected exception to CPUvector 2000, PC = 1CA83C8
-Traceback= 0x1CA83C8z 0x1CA83C8z 0x4C72FCz 0x1340B74z 0x1340D34z 0x1340E50z 0x3
8A1F8z 0x38A66Cz 0x1CA9684z 0x1CA3DD8z
: Unexpected exception to CPUvector 2000, PC = 13802F4
-Traceback= 0x13802F4z 0x1576500z 0x1CA9684z 0x1CA3DD8z
=== Flushing messages () ===
Buffered messages:
Queued messages:
Mar 30 01:27:41.150: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console de
bugging output.
Mar 30 01:27:40.684: %SYS-3-LOGGER_FLUSHED: System was paused for 00:00:00 to en
sure console debugging output.
Cisco IOS Software, C2960S Software (C2960S-UNIVERSALK9-M), Version 15.0(2)SE1,
RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Fri 04-Jan-13 02:38 by prod_rel_team
Debug Exception (Could be NULL pointer dereference) Exception (0x2000)!
SRR0 = 0x013824B8 SRR1 = 0x00029230 SRR2 = 0x01CA83C8 SRR3 = 0x00029230
ESR = 0x00000000 DEAR = 0x00000000 TSR = 0x84000000 DBSR = 0x10000000
CPU Register Context:
Vector = 0x00002000 PC = 0x01CA83C8 MSR = 0x00029230 CR = 0x35000053
LR = 0x01CA83C8 CTR = 0x0037A3C4 XER = 0x80000040
R0 = 0x01CA83C8 R1 = 0x03302C98 R2 = 0x00000000 R3 = 0x033041F8
R4 = 0x00000000 R5 = 0x00000000 R6 = 0x0037AD04 R7 = 0x00000000
R8 = 0x00000002 R9 = 0x00000000 R10 = 0x02B70000 R11 = 0x02B70000
R12 = 0x35000055 R13 = 0x00000280 R14 = 0x0038A624 R15 = 0x00000000
R16 = 0x00000000 R17 = 0x00000000 R18 = 0x00000000 R19 = 0x00000000
R20 = 0x00000000 R21 = 0x00000000 R22 = 0x00000000 R23 = 0x00000000
R24 = 0x00000000 R25 = 0x00000000 R26 = 0x02038568 R27 = 0x02B9B120
R28 = 0x00000001 R29 = 0x00400001 R30 = 0x02C30540 R31 = 0x00000000
Stack trace:
PC = 0x01CA83C8, SP = 0x03302C98
Frame 00: SP = 0x03302CA8 PC = 0x01CA83C8
Frame 01: SP = 0x03302CC8 PC = 0x004C5D24
Frame 02: SP = 0x03302CD0 PC = 0x004C72FC
Frame 03: SP = 0x03302CE0 PC = 0x01340B74
Frame 04: SP = 0x03302D00 PC = 0x01340D34
Frame 05: SP = 0x03302D18 PC = 0x01340E50
Frame 06: SP = 0x03302D48 PC = 0x0038A1F8
Frame 07: SP = 0x03302E50 PC = 0x0038A66C
Frame 08: SP = 0x03302E58 PC = 0x01CA9684
Frame 09: SP = 0x00000000 PC = 0x01CA3DD8
Switch uptime is 20 seconds
cisco WS-C2960S-48TS-L (PowerPC) processor (revision E0) with 131072K bytes of m
emory.
Processor board ID FOC1623X3P1
ā01-18-2013 05:53 AM
Well, the first error you are encountering is "Encryption self-test failed (Software self-integrity test)". If you have a problem with your software integrity, it is likely you had errors with copying the software onto the device. This could have occurred either on the line or in the flash.
Do you still have the old image in the flash, or did you delete it? If you still have it, I would boot that one up and try reloading the new software.
ā01-18-2013 05:59 AM
the old images is deleted during the update prozess because there is not enough space.
ā08-19-2014 05:08 PM
Did you find a solution to that problem. I have the same problem with upgrade of 3 switches. I think it has something to do with bootloader upgrade not working with switches with older hardware revision.
I have tried different IOS, IOS till 15.0(2)SE are working on every switch. 15.0(2)SE1 with FIPS support ist not working on switches with older Model revision.
The switches with booting in loop after upgrade has model revision: D0
The switches with working upgrade has model revision G0 or H0
See also my blog to this problem under: https://supportforums.cisco.com/comment/9887266#comment-9887266
ā01-18-2013 05:54 AM
Did you verify the md5 checksum after loading but before rebooting? If not I would download clean from Cisco, load the new image, verify the checksum and then reboot.
ā01-18-2013 07:41 AM
copy old ios 12.2(58) via xmodem in bootloader mode was successful
switch is now working
ā01-18-2013 07:56 PM
A word of advice: Avoid all IOS versions 12.2(58)SE, 15.0(1)SE and 15.0(2)SE. If you want a stable version, consider 12.2(55)SE6.
