Catalyst 3350 Switch
peternnaji
Level 5
Level 5
When I power up my Catalyst 3550 switch, it boots up and shows "switch:" prompt. and it takes no command afterwards. I wonder what command prompt is "switch:". Please help.
andrew.prince
Level 11
Level 11
This means the switch has NO configuration in it.
You need to start from the begining - read the below:-
http://www.cisco.com/en/US/docs/switches/lan/catalyst3550/software/release/12.2_25_see/configuration/guide/swcli.html
HTH>
viyuan700
Level 10
Level 10
adamclarkuk_2
Level 9
Level 9
That sounds like you have no IOS on the either.
Try the following:-
flash_init
load_helper
dir flash:
if there is an image in there boot from it
deja vu
if not copy one over. The complete procedure is here:
http://www.cisco.com/en/US/products/hw/switches/ps628/products_tech_note09186a0080169696.shtml
