08-04-2007 12:20 PM - edited 03-05-2019 05:42 PM
I have a 3550 I am trying to configure OSPF and get :Unknown routing protocol"
Ususally means the image does not support ospf.
Do I need an image upgrade?
IOS (tm) C3550 Software (C3550-I9Q3L2-M), Version 12.1(22)EA6, RELEASE SOFTWARE
(fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Fri 21-Oct-05 02:12 by yenanh
Image text-base: 0x00003000, data-base: 0x006CF240
ROM: Bootstrap program is C3550 boot loader
Switch uptime is 20 minutes
System image file is "flash:c3550-i9q3l2-mz.121-22.EA6.bin"
cisco WS-C3550-48 (PowerPC) processor (revision E0) with 65526K/8192K bytes of m
emory.
Processor board ID CHK0631V3E9
Last reset from warm-reset
Running Layer2/3 Switching Image
08-04-2007 12:24 PM
The one that you are running is a SMI image. You would need a EMI image to get full L3 routing functionality.
08-04-2007 02:59 PM
Thanks, i just found that out.
Can you upgrade these 3550s?
I have 5526K/8192K bytes of memory and I see now way to upgrade the ram after taking the cover off.
All the EMI images need 16M.
What can I do?
08-04-2007 05:15 PM
I have it now, thanks all.
