10-08-2022 08:50 AM - edited 10-08-2022 09:15 AM
I have an old C3560-8PC-S switch that I would like to use for more than a boat anchor. It currently has IOS 12.2(35)SE5 on it. Does anyone know what the latest IOS is that will run on this device? I would really like to convert to IOS 15 since I've done that on all my other older devices. Due to its age, I am unable to find anything about available IOS images for this device. I have a c2960-lanlitek9-tar.150-2.SE11.tar image. Probably a dumb question, but would a C2960 image run on a C3560 switch?
Thanks for any help I can get.
Solved! Go to Solution.
10-08-2022 11:37 AM
@RIck Carlisle ok, checking my 3560 8 port switch it's the WS-C3560-8PC model (not the 3560C model) and it supports 15.0(2), though there isn't a direct link to download this image on the cisco site.
Switch Ports Model SW Version SW Image
* 1 9 WS-C3560-8PC 15.0(2)SE10 C3560-IPSERVICESK9-M
Configuration register is 0xF
3560-8#show boot
BOOT path-list : flash:/c3560-ipservicesk9-mz.150-2.SE10.bin
10-08-2022 06:49 PM
@RIck Carlisle wrote:
Thanks Leo but it's not a 3560C. It's an old straight WS-C3650-8PC.
3560-8PC is a compact switch. It is the "start" of the compact switch line. I will forever call it "compact".
The IOS files I have responded is compatible to the 3560-8PC because we have one or two lying around the storeroom somewhere.
10-09-2022 09:28 AM
You can get the image from below link :
https://software.cisco.com/download/home/282526527/type/280805680/release/15.0.2-SE11
10-08-2022 10:46 AM
as per i know latest is - 12.2.55-SE12 (if you have CCO account you can download and install) - make sure you keep copy of the existing version also in case required.
This is not support - never do that, this will brick your box.
10-08-2022 11:23 AM
Thank you SIr!
I was pretty sure using a 2960 image wouldn't work but it was worth asking. I do have a CCO account but it's a guest account until we can get a service contract in place. Working with sales on that. We acquired this and a number of other Cisco devices as part of an asset purchase from Chevron. With regard to the 15 upgrade, do you know if there is a 15.2-SE11 image for the old 3560?
10-09-2022 09:28 AM
10-09-2022 09:34 AM
BB, thank you Sir. I found the links. I have the 15.0.2-SE11 and the 12.2.55-SE12 tar and bin files.
10-08-2022 11:23 AM
@RIck Carlisle I still run the 3560 8 port switch, it's a great little switch, it supports 15.2. Download link https://software.cisco.com/download/home/283915797/type/280805680/release/15.2.2E10
10-08-2022 11:27 AM
Rob,
Thanks for the info. Unfortunately, my switch is not a 3560C. It's an old WS-3560-8PC-S. I'm pretty sure the 3560C image won't run on the old 3560. It would be great if I'm wrong about that.
10-08-2022 11:37 AM
3560-8#show boot
10-08-2022 01:44 PM
Rob,
Thanks for the file name! I was able to find these files on the cisco site.
c3560-ipbasek9-mz.150-2.SE11.bin, c3560-ipbasek9-tar.150-2.SE11.tar, c3560-ipbasek9-mz.150-2.SE10.bin and c3560-ipbasek9-tar.150-2.SE10.tar. Release notes seem to say these are all compatible with the WS-C3560-8PC.
Also found these, c3560-ipbasek9-mz.122-55.SE12.bin and c3560-ipbasek9-tar.122-55.SE12.tar. The link to the release files for the 12.2 images is broken so I can't confirm these are good images.
I think I'll go ahead and back up the current image and try the 15.0(2)SE11 image and see how it goes.
Thanks again!
10-08-2022 04:47 PM
There are two IOS versions that can support 3560C (compact), and they are:
These two trains are considered the most stable (and second only to SXI and SXJ). Download the TAR files.
10-08-2022 04:49 PM
10-08-2022 06:49 PM
10-09-2022 08:10 AM - edited 10-09-2022 08:14 AM
Thanks Leo. It's been about 20 years since I had to get into the IOS. I think the last switch I programmed was a 4048G (4824G ? can't remember the number). It was the first layer 3 switch Cisco made (I think). Haven't done much between then and now. Funny how it starts to come back.
Thanks for your help!
