Catalyst 3560 dot1x reauthentication timers?
I have wired 802.1x deployed with XP SP3 & Vista SP1 clients on a 3560 running the latest 12.2(50)SE software. Radius is handled by a Windows 2003 Server & IAS and reauthentication is enabled using the server to provide the timeout (session-timeout set to 180 minutes). This all appears to work but reauthentication seems to be happening more frequently than the supplied timeout. The logs filtered for 1 port are attached.
The port configuration is:
interface FastEthernet0/2
switchport access vlan 10
switchport mode access
switchport voice vlan 15
switchport port-security maximum 3
switchport port-security maximum 2 vlan access
switchport port-security maximum 1 vlan voice
switchport port-security aging time 3
switchport port-security violation restrict
switchport port-security aging type inactivity
no logging event link-status
srr-queue bandwidth share 1 70 25 5
srr-queue bandwidth shape 3 0 0 0
priority-queue out
authentication port-control auto
authentication periodic
authentication timer restart 30
authentication timer reauthenticate server
authentication violation protect
no snmp trap link-status
dot1x pae authenticator
spanning-tree portfast
service-policy input IPPHONE+PC-BASIC
ip dhcp snooping limit rate 100
The session-timeout is seen by the switch:
cat-3560-48-s1#sho authentication sessions interface fastEthernet 0/1
Interface: FastEthernet0/1
MAC Address: 000c.f18c.c8fd
IP Address: 192.168.100.60
User-Name: DOMAIN\user
Status: Authz Success
Domain: DATA
Oper host mode: single-host
Oper control dir: both
Authorized By: Authentication Server
Vlan Policy: N/A
Session timeout: 10800s (server), Remaining: 9415s
Timeout action: Reauthenticate
Idle timeout: N/A
Common Session ID: C0A864FE00000D7A2F7C13F4
Acct Session ID: 0x00000E7A
Handle: 0x89000D7A
Runnable methods list:
Method State
dot1x Authc Success
The times between reauthentications is also not consistent (23-minutes, 5.5-minutes, 23-minutes, 5.5-minutes, 37-minutes, 5.5-minutes, 30-seconds, 26.5-minutes, 5.5-minutes, 17.5-minutes)
I am not sure if the client is initiating the reauthentication but I don't remember seeing any settings in either XP or Vista for timers? I have also looked at the GPO settings and there is nothing about reauthentication timers (XP SP3 & Vista can get the Wired 802.1x settings from GPO).
Has anyone else seen this? Is it the client or is it the switch? Is it fixable?
Cheers
Andy
0 Replies 0
