Showing results forĀ
Search instead forĀ
Did you mean:Ā
Catalyst 3560-X IOS 15.0(2) IP Base
kerstin-534
we have observed increase of CPU utilization of 50% after upgrade from 15.0(1)SE3 to 15.0(2).
The SDM template is  "desktop default" template.
The increase of CPU utilization in Switches with LAN Base after upgrade is about 10%.
Has somebody an idea to find the cause for the 50% increase ?
This is command is the output of 15.0(2). The calculated sum for 5min process-utilization is 21% plus
1% interrupt is 22 %. Where is the rest ?
switch#sh proc cpu  sorted 5min | exc 0.00
CPU utilization for five seconds: 30%/1%; one minute: 29%; five minutes: 28%
PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
169   135084171    33273787       4059  9.92%  8.94%  8.73%   0 Hulc LED Process
  83    80075989    13546109       5911  5.60%  5.39%  5.38%   0 RedEarth Tx Mana
  82    35961521    22044350       1631  2.40%  2.58%  2.57%   0 RedEarth I2C dri
   4    23049116     1025093      22485  2.87%  1.16%  1.52%   0 Check heaps
126    12684154     1334361       9505  0.79%  0.91%  0.89%   0 hpm counter proc
233    14289030    36476685        391  0.95%  0.90%  0.88%   0 Spanning Tree
181     4784768      265620      18013  0.31%  0.35%  0.32%   0 HQM Stack Proces
401     3112704     4956783        627  0.15%  0.21%  0.21%   0 SNMP ENGINE
  54     1528521     1334812       1145  0.31%  0.13%  0.11%   0 Per-Second Jobs
182     1521435      531267       2863  0.15%  0.11%  0.10%   0 HRPC qos request
302     1463582     2928584        499  0.15%  0.10%  0.10%   0 Marvell wk-a Pow
249     1373699     1322338       1038  0.15%  0.08%  0.10%   0 PI MATM Aging Pr
107     1522052    37139967         40  0.31%  0.06%  0.09%   0 HLFM address ret
400      886100     4956777        178  0.15%  0.04%  0.04%   0 PDU DISPATCHER
regards,
Herbert
17 Replies 17
Arumugam Muthaiah
Hi Herbert,
When you check the cpu utilization, it will show the three different values like 5 secs, 1 min, 5 mins average CPU utilization. These are the values which combine process which utilize the CPU respectively.
  • In our case, The first number, 30%, tells how busy the CPU was in the past 5 seconds. This number is the total CPU utilization for all the active system processes, including the percentage of time at the interrupt level.
  • The second number, 1%, shows the percentage of time at the interrupt level in the past 5 seconds. The interrupt percentage is the CPU time spent receiving packets from the switch hardware. The percentage of time at interrupt level is always less than or equal to the total CPU utilization
I could see that the process Hulc LED Process utilized more CPU percentage. There is some known Bug matching this issue
CSCtn42790 - 3560X/3750X: Elevated CPU usage due to Hulc LED process
Symptom:
Hulc LED Process uses 15-30% CPU on Catalyst 3560X/3750X platforms.
Conditions:
The is seen in 12.2(53)SE releases or later.
Workaround:
This is an expected behavior and there is no workaround.
Further Problem Description:
The "Hulc LED" process does following tasks:
  • Check Link status on every port
  • If the switch supports POE, it checks to see if there is a Power Device (PD) detected
  • Check the status of the transceiver
  • Update Fan status
  • Set Main LED and ports LEDs
  • Update both Power Supplies and RPS
  • Check on system temperature status
Please observe the average CPU utilization and share the result
# show proc cpu history
# show platform port-asic stats drop
# show controllers cpu-interface
Refer:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/troubleshooting/cpu_util.html
Aru
*** Please rate if the post is useful ***
Regards, Aru *** Please rate if the post useful ***
Hi Aru,
I have uploaded the 3 show commands.
Back to my question:
Where is the difference between the sum of all processes and the output of
"show proc cpu" ?
The interrupt level is constant with 1%. (I have seen some trouble if there is a lot of
zeroconf service).
In previous releases it was sufficient to disable all unused interfaces to decrease the cpu utilization.
This is useless in this case.
regards,
Herbert
Hi Herbert,
Sorry for the delay. i verified the capture and understood that your average CPU utilization is 30%
      455555544554455554544454455454455454455444444554555454454545545445454555
      910600377036914038378916741839901908701899999109402718829082172970918300
  100
   90
   80
   70
   60    *
   50 **********************************************************************
   40 **********************************************************************
   30 ######################################################################
   20 ######################################################################
   10 ######################################################################
     0....5....1....1....2....2....3....3....4....4....5....5....6....6....7..
               0    5    0    5    0    5    0    5    0    5    0    5    0
                   CPU% per hour (last 72 hours)
                  * = maximum CPU%   # = average CPU%
  • I tried to verify the same calculation in another switch and i tried to add the 5 mins utilization and found that there is small mismatch with total CPU percentage still.
  • i hope the switch is pulling up avergage data vs instant process consumption
Switch#sh proc cpu sort 5min
CPU utilization for five seconds: 3%/2%; one minute: 2%; five minutes: 2%
  24     6243252  75514754         82  0.87%  0.33%  0.35%   0 IPC Seat Manager
   9     4651464    305202      15240  0.00%  0.29%  0.27%   0 Check heaps
258     1064396    302344       3520  0.00%  0.09%  0.09%   0 CDP Protocol
285        2980 208738526          0  0.07%  0.09%  0.07%   0 Ethernet Msec Ti
  51       13516   1648917          8  0.00%  0.05%  0.07%   0 Per-Second Jobs
342      525216   2418370        217  0.15%  0.05%  0.05%   0 CEF: IPv4 proces
462        4112 102767277          0  0.07%  0.05%  0.05%   0 HSRP Common
  52      988728     29231      33824  0.00%  0.03%  0.05%   0 Per-minute Jobs
363      139800    824337        169  0.00%  0.03%  0.02%   0 HIDDEN VLAN Proc
465      467156   2800171        166  0.00%  0.02%  0.01%   0 Port manager per
Aru
Leo Laohoo
If you have 3560/G/E/X and/or 3750/G/E/X, then stay away from using IOS version 15.0(1)SE (and later) and 15.0(2)SE.
Instead, look into 12.2(55)SE6.
please can you comment your findings why not use 15.0(x).
thank you,
Herbert
Sure, to sum it all up:  If you enjoy watching your fleet of 3560/G/E/X and/or 3750/G/E/X continuously having CPU spikes and crashing (as a result), then 15.0(1)SE and 15.0(2)SE is your bet.
Unless there are specific functions you need with the IOS versions you need, then 12.2(55)SE6 is one of THE most stable versions of IOS.
All of my 3560/G/E/X and/or 3750/G/E/X are running this version.  Search through the forums of users having issues with their Catalyst switches and running these two versions.  You'll find a lot of them.
From my side:
there is a feature that starts with 15.0(2) - disable physical sleep mode.
There are people that are happy because some Broadcom NICs did not work with C3750-X. (they got no link)
IPv6 First Hop Security causes c3750-X to crash in a round robin manner in 15.0(2).
That's one reason and I won't talk you out of using 15.0(2)SE.
May I be able to provide you with an advice?
I like to call IOS, versons without any numbers at the end, as version "0".  It's like Windows 7 RTM.  What I'm saying is this:  Keep a sharp eye on any further/later releases to 15.0(2)SE, or versions with numbers at the end like 15.0(2)SE1 or 15.0(2)SE2, etc.  This means that there were bug fixes.  I am not sure if you are aware but Cisco there are two "types" of bugs.  One is public-knowledge bugs and the other is internal bugs.
I always thought this is constructive forum. Things as explaining version numbers is something of a really odd thing or comparisons with Windows 7.
best regards,
Herbert
Sorry, wasn't meant to be offensive or insulting.
But the relevance is there.  When MS released the OS to PC/Laptop manufacturer, it's called RTM or "Release To Mananufacturer".  You can call this version "0".
Same with IOS versions.  IOS versions without a number at the very end is simply known as version "0".
Hi Leo,
how about 2960,still 122-55.SE6?
2960/G/S?  No problem with 15.0(2)SE.
Just don't do any TDR.  You'll get a heart attack!
I have change 3750X to
Switch Ports Model              SW Version            SW Image
*    1 54    WS-C3750X-48P      12.2(55)SE6           C3750E-UNIVERSALK9-M
But,the cpu usage
CPU utilization for five seconds: 29%/0%; one minute: 29%; five minutes: 29%
a little high ,  is it nornal.......?
Yes, This is an expected behavior, in this platform.
The Catalyst 3750-X switches have a CPU utilization level that is higher than the previous models of the Catalyst 3750 switches. This is normal behavior. One can expect that the overall CPU utilization will be between 25 – 35%.
Since almost all of the packet forwarding is done in hardware and not by the CPU a CPU utilization of 25 – 35% should not be cause for concern.
Please check the show proc cpu sort | ex 0.00% and share the detail.
Aru
