Catalyst 3650 OS image not auto booting
befox2261
The switch I'm currently having issues with is not automatically booting the OS image after a power outage, I have to manually boot flash:<OS> every time.  here is my switch information.
during boot I get:
The system is unable to boot automatically. The
BOOT environment variable needs to be set to a
bootable image.
my flash:
72722 drwx 4096 Dec 23 2024 16:17:11 +00:00 .installer
72724 -rw- 481 Dec 23 2024 16:17:14 +00:00 bootloader_evt_handle.log
72725 drwx 4096 Dec 19 2024 21:21:48 +00:00 core
72726 drwx 4096 Dec 23 2024 16:19:15 +00:00 .prst_sync
72728 drwx 4096 Dec 19 2024 17:42:40 +00:00 .rollback_timer
72731 drwx 4096 Dec 19 2024 17:42:45 +00:00 gs_script
72732 drwx 4096 Dec 19 2024 17:42:45 +00:00 tech_support
72758 drwx 4096 Dec 23 2024 16:17:28 +00:00 dc_profile_dir
72763 -rw- 132108 Dec 23 2024 16:17:51 +00:00 memleak.tcl
72764 -rw- 76 Dec 23 2024 16:17:32 +00:00 boothelper.log
72765 -rw- 0 Dec 23 2024 16:19:05 +00:00 rdope_out.txt
72768 -rw- 545 Dec 23 2024 16:19:16 +00:00 rdope.log
72770 drwx 4096 Dec 20 2024 18:54:29 +00:00 .dbpersist
72767 -rw- 76 Dec 23 2024 15:06:51 +00:00 boothelper.old
72769 -rw- 2097152 Dec 23 2024 16:19:39 +00:00 nvram_config
72771 -rw- 2097152 Dec 23 2024 16:19:39 +00:00 nvram_config_bkup
72772 drwx 4096 Dec 19 2024 21:21:28 +00:00 onep
72775 -rw- 29452 Dec 19 2024 21:27:29 +00:00 collated_log_20241219-212729
72776 -rw- 383 Dec 19 2024 21:27:29 +00:00 btdecode_err
72777 -rw- 35 Dec 20 2024 18:37:11 +00:00 pnp-tech-time
72778 -rw- 108530 Dec 20 2024 18:37:19 +00:00 pnp-tech-discovery-summary
72779 -rw- 482681593 Dec 19 2024 21:52:38 +00:00 cat3k_caa-universalk9.16.12.12.SPA.bin
my show boot:
Switch 1
Current Boot Variables:
BOOT variable = flash:cat3k_caa-universalk9.16.12.12.SPA.bin;
Boot Variables on next reload:
BOOT variable does not exist
Manual Boot = no
Enable Break = no
Boot Mode = DEVICE
iPXE Timeout = 0
My Register:
Configuration register is 0x102
Things I have tried:
  1. tried to reset the boot variable
MySwitch(config)#no boot system
MySwitch(config)#boot system flash:cat3k_caa-universalk9.16.12.12.SPA.bin
MySwitch(config)#no boot manual
MySwitch(config)#do wr
MySwitch#reload
      2. Tried setting Register to Ox2102, after I set it, write, and reload. it doesn't stick. not sure if this is even my issue.
This is not expected for sure.
   what I would try is bring a new IOS to this switch and  run the process in install mode intead the bundle mode you are using now.
 https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3650/software/release/3se/system_management/configuration_guide/b_sm_3se_3650_cg/b_sm_3se_3650_cg_chapter_010101.html
5 Replies 5
@befox2261
 "2. Tried setting Register to Ox2102, after I set it, write, and reload. it doesn't stick. not sure if this is even my issue. "
  OK but you need to keep this value. Your problem may be something else but this will cause you others problems if you dont configure it as 2102
While in switch: mode, check if you have this configured
SWITCH_IGNORE_STARTUP_CFG=0
so I thought you were on to something, I thought I might of forgot to change that value back after I did factory reset a few weeks ago, so I did the following:
enter Rommon Mode:
Initializing Flash...
flashfs[7]: 0 files, 1 directories
flashfs[7]: 0 orphaned files, 0 orphaned directories
flashfs[7]: Total bytes: 6784000
flashfs[7]: Bytes used: 1024
flashfs[7]: Bytes available: 6782976
flashfs[7]: flashfs fsck took 1 seconds....done Initializing Flash.
switch: set SWITCH_IGNORE_STARTUP_CFG = 0
boot flash:cat3k_caa-universalk9.16.12.12.SPA.bin
MySwitch>en
MySwitch#conf t
MySwitch(config)#config-register 0x2102
MySwitch(config)#end
MySwitch#wr
MySwitch#reload
same results, don't autoboot and and register is still 0x102
Thank you, after doing this seemed to resolve my issue, for those who are interested this is what I had to do:
Switch# install file flash:/cat3k_caa-universalk9.16.12.12.SPA.bin activate commit
switch: rebooted
set the variables again
switch:flash_init
switch: set BYPASS_STARTUP_CONFIG = 0
I now have the following in flash:
switch: dir flash:
Directory of flash:/
32321 drwx 4096 .
2 drwx 4096 ..
32322 drwx 4096 .installer
32324 -rw- 37 bootloader_evt_handle.log
32325 drwx 4096 core
32326 drwx 4096 .prst_sync
32328 drwx 4096 .rollback_timer
32331 drwx 4096 gs_script
32332 drwx 4096 tech_support
32358 drwx 4096 dc_profile_dir
32362 -rw- 76 boothelper.log
32364 -rw- 132108 memleak.tcl
32365 drwx 4096 .dbpersist
32366 -rw- 0 rdope_out.txt
32367 -rw- 545 rdope.log
32368 -rw- 2097152 nvram_config
32369 -rw- 2097152 nvram_config_bkup
32370 drwx 4096 onep
32373 -rw- 35 pnp-tech-time
-- MORE --
32374 -rw- 117973 pnp-tech-discovery-summary
72733 -rw- 20095620 cat3k_caa-guestshell.16.12.12.SPA.pkg
72737 -rw- 34849875 cat3k_caa-rpbase.16.12.12.SPA.pkg
72734 -rw- 401289852 cat3k_caa-rpcore.16.12.12.SPA.pkg
72736 -rw- 3418756 cat3k_caa-srdriver.16.12.12.SPA.pkg
72735 -rw- 23022208 cat3k_caa-webui.16.12.12.SPA.pkg
72732 -rw- 4781 packages.conf
since I haven't set the boot variable since I deleted it I boot to the Packages.conf
switch: boot flash:packages.conf
set boot variable to packages.conf
Switch#conf t
Switch(config)#boot system flash:packages.conf
Switch(config)#end
Switch(config)#end
Switch#wr
Building configuration...
*Dec 23 21:48:21.232: %SYS-5-CONFIG_I: Configured from console by console[OK]
Switch#reload
@befox2261
 Thank you very much for sharing.
