Catalyst 3650 Rommon flash Read only
cleetusant
Hello
My Catalyst WS-3650-48TS switch shows read only flash file system.
After IOS upgrade, switch went to rommon mode.
While trying to boot from USB, it shows not enough memory for Full image.
I tried to delete some files and make room for booting. Switch doesn't allow me to delete files from flash.
Please guide to fix it.
Below given the output of various command I used.
Booting...Initializing RAM +++++++@@@@@@@@...++++++++++++++++++++++++++++++++@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@done.
Memory Test Pass!
Base ethernet MAC Address: 10:05:ca:e3:6b:80
Interface GE 0 link down***ERROR: PHY link is down
Initializing Flash...
flashfs[7]: 0 files, 1 directories
flashfs[7]: 0 orphaned files, 0 orphaned directories
flashfs[7]: Total bytes: 6784000
flashfs[7]: Bytes used: 1024
flashfs[7]: Bytes available: 6782976
flashfs[7]: flashfs fsck took 2 seconds....done Initializing Flash.
Not enough free memory for entire image
flash:cat3k_caa-universalk9.16.03.08.SPA.bin: bad/non-bootable Nova bundle file
Error loading "flash:cat3k_caa-universalk9.16.03.08.SPA.bin"
Interrupt within 5 seconds to abort boot process.
: no such device
: no such device
Error loading ""
switch: dir
List of filesystems currently registered:
xmodem[0]: (read-only)
null[1]: (read-write)
bs[3]: (read-only)
flash[18]: (read-only)
usbflash0[19]: (read-write)
tftp[20]: (read-write)
switch: dir flash:
Directory of flash:/
30977 drwx 4096 .
2 drwx 4096 ..
30978 -rw- 79121160 cat3k_caa-base.SPA.03.03.03SE.pkg
30979 -rw- 6484668 cat3k_caa-drivers.SPA.03.03.03SE.pkg
30980 -rw- 34522096 cat3k_caa-infra.SPA.03.03.03SE.pkg
30981 -rw- 34821452 cat3k_caa-iosd-universalk9.SPA.150-1.EZ3.pkg
30982 -rw- 25131920 cat3k_caa-platform.SPA.03.03.03SE.pkg
30983 -rw- 77312832 cat3k_caa-wcm.SPA.10.1.130.0.pkg
30984 -rw- 1248 packages.conf
30985 -rw- 2097152 nvram_config
30986 -rw- 796 vlan.dat
30987 -rw- 535578976 cat3k_caa-universalk9.16.03.08.SPA.bin
823619584 bytes available (824274944 bytes used)
switch: delete flash:cat3k_caa-universalk9.16.03.08.SPA.bin
Are you sure you want to delete "flash:cat3k_caa-universalk9.16.03.08.SPA.bin" (y/n)?y
File "flash:cat3k_caa-universalk9.16.03.08.SPA.bin" not deleted -- read only file system
switch: format flash:
Are you sure you want to format "flash:" (all data will be lost) (y/n)?y
Filesystem "flash:" not formatted -- invalid argument
Cleetus
Seb Rupik
Hi there,
Have tried to recover the old installation? It looks like you were previously running in INSTALL mode. From ROMMON can you issue the command
boot flash:packages.conf
...see it this will allow IOS-XE to load. You can then attempt your upgrade again.
cheers,
Seb.
Seb Rupik
Hi there,
cheers,
Seb.
I'm having the same problem. But when I boot from flash:packages.conf, the IOS-XE loads but then keeps restarting. Here is the complete message from boot to restart, link. Any help will be appreciated, thank you.
I'm just wondering if you had any luck with this issue? I experiencing the same thing.
cleetusant
Thank you Seb. I missed that point.
