Catalyst 3750 LAN Routing (Help ...)
egemen1981
İs it Possible to routing between the subnets below?
Clients : 192.6.1.0/23
GW(Catalyst 3750) : 192.6.1.7/23
Catalyst Default Route : 192.6.1.240 /24
What I want to achive is , 192.6.0.1-192.6.0.254 Clients can access to default gateway and can access other networks?
Regards.
2 Accepted Solutions
IMHO, it seems you've got wrong subnet mask configured on your Catalyst.
Change it from /24 to /23 and everything should work.
BTW, I suppose you are using /23 subnet mask on your clients.
Why don't you configure your clients to use 192.6.1.240 as their default GW?
HTH,
Milan
The cat default GW subnet is overlapping the /23 subnet:
/23 - 192.6.0.1 - 192.6.1.254
/24 - 192.6.1.1 - 192.6.1.254
As Milan says, change the Cat default GW to the /23 subnet
Latchum Naidu
The 192.6.0.1 network is different from the default gateway network.
You need to have VLAN's create on the Catalyst 3750 in order to make routing between 192.168.6.0/23 and 192.168.0.1/24 networks
Please click on the correct answer if this answered your question.
Naidu.
I Think there is a misunderstanding about subnets.
Our subnet is 192.6.1.0/23 (IP Range 192.6.0.1-192.6.1.254)
Client gateway is our catalyst switch (192.6.1.7/23)
Catalyst default GW is 192.6.1.240/24
All Clients((IP Range 192.6.0.1-192.6.1.254) can ping to 192.6.1.7 normally but Catalyst does not route (192.6.0.1-192.6.0.254) packets to its default gateway (192.6.1.240).
Catalyst only routes packet from clients(192.6.1.1-192.6.1.254) to  its default GW(192.6.1.240).
HTH,
Milan
